Autor Subiect: sfat ulei  (Citit de 43099 ori)
Offline cristeck
  • Mesaje postate: 25
Re: sfat ulei
« Răspuns #87 : August 11, 2010, 02:54:39 p.m. »
Eu am pus de la prima revizie YACCO VX1703 (parca) 5W40 pentru diesel. Sunt f multumit de el. Acum o luna si ceva am avut cea de-a 2-a revizie si am pus acelasi ulei. Daca tot te interesezi de uleiuri vezi sa aiba omologare pt motoare VW.
SKODA OCTAVIA TOUR, 1.9 TDI, 101CP, AN 2008
Offline Cornel
  • Locaţia: Bucuresti, R.F.G.
  • Mesaje postate: 215
  • Auto: O2, BSE, 1.6 MPI
Re: sfat ulei
« Răspuns #86 : August 11, 2010, 11:33:42 a.m. »
Trebui sa fac revizia de doi ani (17.000 km :D ).
La prima revizie am folosit Ulei Castrol SLX Professional 5W40 502.00/505.00.
Stiti cineva a aparut ceva nou ce vine ca imbunatatire, sau sa-l folosesc tot pe asta?
Post Merge: August 11, 2010, 11:53:16 a.m.
Da, am gasit ceva. Imi "aduce cineva" 5W30.
Am cautat pe internet si am vazut ca se foloseste si la benzina si la TDI!
« Ultima Modificare: August 11, 2010, 11:53:16 a.m. de Cornel »
Offline arkadyema
  • Locaţia: Bossimania--Buzau
  • Mesaje postate: 244
  • simply clever
  • Auto: 1,9TDI Octi 2 NEW
Re: Ulei Octavia 2 - 1.9 TDI
« Răspuns #85 : Ianuarie 22, 2010, 06:39:32 p.m. »
My bad...ai dreptate..BXE doar pt O2 non RS!
Da si daca e din afara Romaniei posibil ca acolo toate sa fie dotate pentru respectarea normelor de poluare!
CHECK THIS OUT
The SLX Professional LLO3 5w-30 meets VW 504 00 and 507 00 it does not meet the VW 505 01 specification. The 505.01 engine oil is specifically formulated to ensure protection of the cam lobes that drive the unit injectors. High loading requires the proper level of antiwear protection. In turn VW needs to ensure that 505.01 is utilized for this engine design. The cam shafts are mechanically driven and assist in the build up of fuel pressure in each injector.
Castrol 505 01 is only available in North America through VW dealerships.** It is branded as Castrol 505 01 or Castrol SLX professional oil and has a VW part number (ZVW-352-167-Q-DSP).
« Ultima Modificare: Februarie 14, 2010, 06:42:34 p.m. de arkadyema »
Offline C o s m i n
  • Mesaje postate: 5853
  • ZEN Master
  • Auto: Fabia 287 Nm
« Răspuns #84 : Ianuarie 22, 2010, 09:45:07 a.m. »
Motorul BXE e de 1.9 105 cai, ori RS diesel e de 2 litri 170 de cai. Dar daca masina nu e noua, si e adusa din strainatate e posibil sa fie cu DPF. Si adi.n PD nu e tot una cu DPF. PD=Pompe duse se refera la tipul injectiei de motorina, DPF se refera la un filtru al particulelor din fumul de diesel montat pe esapament.
Offline arkadyema
  • simply clever
« Răspuns #83 : Ianuarie 21, 2010, 06:31:21 p.m. »
@COSMIN...ai dreptate. ceea ce doresc eu e o functionare cat mai buna. se pare..doar se pare ca acest 507.00 e "mai bun"...insa vorba ta "muuulti km" inseamna mult. Dupa cum am mai zis..nu prea avem unde sa facem o analiza la ulei..altfel ar fi stat topurile acum. Dar 505.01 e poate cea mai buna alegere..totusi o sa incerc 507.00. Diferenta de pret nu e mare.
Acum nu sunt sigur...dar BXE cu DPF e pe RS parca..Pentru O2(non RS) nu cred ca exista motor cu DPF..sau gresesc?
Cum au zis colegii 507.00 e pentru masini cu DPF- Diesel particule filter- adica filtru pentru particule diesel. si norma e 5w30!!Dar atentie mergeti dupa norma VW...adica acel 507.00/504.00, ele sunt la fel si merg la orice tip de motor- benzina sau diesel!
Succes!
Preturi normale: ulei injur de 40 ron/litru ceva 507.00, filtrul ulei 23-25 ron, filtru aer 35-45 ron maxim MANN, habitaclu 35-45 cu carbon activ. filtru motorina MANN pu825x am gasit cu 60 ron! Motor BXE, euro 4!
Succes!
LUCI va sta la dispozitie cu preturi foarte bune!
Offline claudiubwr
  • Auto: e36
« Răspuns #82 : Ianuarie 21, 2010, 05:34:17 p.m. »
daca as avea seria de caroserie ti-as putea spune daca ai sau nu filtru de particule
« Ultima Modificare: Ianuarie 21, 2010, 05:44:06 p.m. de M i c u t z u »
Offline adi.n
  • Mesaje postate: 15
« Răspuns #81 : Ianuarie 21, 2010, 04:31:45 p.m. »
de la reprezentanta mi-au zis ca motorul meu BXE e cu pompe duse si nu cu filtru de particule
Octavia II 1.9 TDI
Offline claudiubwr
  • Auto: e36
« Răspuns #80 : Ianuarie 21, 2010, 04:17:41 p.m. »
baga ulei 5w30 cu norma 50700/50400 ca asat e pentru masini cu filtru de particule
asata dac nu vrei sa schimbi filtrul de particule mai curand decat e cazul
« Ultima Modificare: Ianuarie 21, 2010, 05:44:53 p.m. de M i c u t z u »
Offline adi.n
« Răspuns #79 : Ianuarie 21, 2010, 03:49:40 p.m. »
Inca ceva...
imi spune mecanicul meu ca motorul meu e cu filtru de particule si nu "pompe duse"
eu data trecuta am pus Aral 431 tronic 5w40 iar acum mecanicul imi spune ca uleiul asta nu e pentru masini cu filtru de particule.
iar uleiul mentionat in postul anterior e mobil 5w30 esp formula 507.00 care costa cam peste tot 48 ron/l
ce sa fac acuma....sa trec la ulei pentru filtru de particule sau sa raman la cel vechi...
Octavia II 1.9 TDI
Offline C o s m i n
  • ZEN Master
« Răspuns #78 : Ianuarie 21, 2010, 12:46:25 p.m. »
uleiul e scump. Cauta aici pe forum topicul lui LUCI cu vanzare de ulei si filtre. Cere-i o oferta.
Offline adi.n
« Răspuns #77 : Ianuarie 21, 2010, 12:36:18 p.m. »
Am primit o oferta de consumabile:
ulei 5L Mobil - 249.90f. ulei - 24.76f. motorina - 86.12f. aer - 44.96f. polen  - 36.24
cum vi se par preturile.
e vorba de ceva firma din cluj
Octavia II 1.9 TDI
Offline C o s m i n
  • ZEN Master
« Răspuns #76 : Ianuarie 21, 2010, 09:50:53 a.m. »
arkadyema, pentru motorul TDI 1.9 euro 3 si euro 4 norma e 505.01. Norma ulterioara 507.00 este acoperitoare in sensul ca include si 505.01. Personal nu bag 507.00 pentru simplul motiv ca masina a mers foarte bine cu 505.01 muuuuulti km, si nu schimb ceva ce se dovedeste functional. Iar 5W-40 bag de cand am masini pentru ca mi se pare un ulei versatil si potrivit pentru orasul in care traiesc si drumurile pe care le fac atat vara cat si iarna. 5W-30 sau 0W-30 ar fi cred un adevarat festin pentru motorul meu...si am vazut ca tdi cu uleiul asta care e mai subtire e mult mai "clantos"(a se intelege zgomotos).
Acuma...asta e parerea mea subiectiva, sunt de acord ca exista si alte pareri, si sunt de idee ca pana nu incerci mai multe variante nu ai cum sa alegi cel mai potrivit ulei pentru masina ta si pentru tine.
Offline Harlequin
  • Mesaje postate: 1460
  • Auto: SKODA Tour
« Răspuns #75 : Ianuarie 20, 2010, 11:06:33 p.m. »
nu colegu' ulei castrol edgge (bidon auriu) la 5l 140 ron se gaseste in targ la vitan la magazinele de acolo,,tot de acolo am cumarat si eu,si toate filtrele mann la preturi ft bune
Asta vrea sa fie Castrol Edge sau e un fel de Abidas, Pamasonic, Rebbok?
Offline arkadyema
  • simply clever
« Răspuns #74 : Ianuarie 20, 2010, 06:18:58 p.m. »
Stiam eu ceva de 508.00 poate ca asta va fi pentru motoarele E6 diesel/benzina... :-/
Offline ovidelu08
  • Locaţia: BUCURESTI, P-ta Moghioros
  • Mesaje postate: 307
« Răspuns #73 : Ianuarie 20, 2010, 06:13:08 p.m. »
chiar E6
2.5 D, 180 CP    (ex Skoda Octavia2)
please help de M i c u t z u
Re: please help de vizitator
please help de castelan
13 14 15 16 17 18 19
27 28 [29] 30
