Autor Subiect: Emission Fault workshop  (Citit de 100004 ori)
Re: Emission Fault workshop
« Răspuns #130 : Ianuarie 30, 2014, 07:17:10 a.m. »
Codul motorului e scris in talon, carte si pe carcasa distributiei.
Tu ai 4 bujii arese si un senzor de temperatura combustibil defect. Verifica firele de la senzor.
Offline professore
  • Auto: Octavia 2 1.9 TDI
« Răspuns #129 : Ianuarie 29, 2014, 10:35:02 p.m. »
Am o skoda octavia 2 1.9 tdi 2005, luni dimineata cand am plecat, la 8-10km la ora mi s-a aprins martorul check engine cu eroarea emissions workshop. Azi am reusit sa pun un tester sa vad ce zice computerul. Rog pe cei care se pricep mai bine sa imi dea un sfat inainte sa ajung cu ea la un service sa rezolv toate cele. Ce as putea eu sa fac inainte sa o duc la service si ce ar trebui schimbat la ea?
Am observat ca are "Address 01: Engine        Labels: 03G-906-016-BKC.lbl"; asta ar insemna ca motorul este tip BKC?
   Wednesday,29,January,2014,20:38:41:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: TMBBS61Z752035133   License Plate: 12345
Mileage: 200550km-124615mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72
VIN: TMBBS61Z752035133   Mileage: 200550km/124615miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Sporadic communication error 1000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
   Part No SW: 03G 906 016 DJ    HW: 028 101 188 3
   Component: R4 1,9L EDC G000SG  6250
   Revision: 12345678    Serial number: SKZ7Z0D2771009
   Coding: 0000071
   Shop #: WSC 73430 790 00000
   VCID: 6ED328337962DE6E76F-803B
5 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 924 /min
                    Torque: 70.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.67 V
                    Bin. Bits: 00101100
                    Temperature: 0.0°C
                    Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
            P0672 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 924 /min
                    Torque: 70.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.67 V
                    Bin. Bits: 00101100
                    Temperature: 0.0°C
                    Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 924 /min
                    Torque: 70.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.67 V
                    Bin. Bits: 00101100
                    Temperature: 0.0°C
                    Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
            P0674 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 924 /min
                    Torque: 70.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.67 V
                    Bin. Bits: 00101100
                    Temperature: 0.0°C
                    Bin. Bits: 10110000
16567 - Fuel Temp. Sensor A (G81)
            P0183 - 000 - Open or Short to Plus
             Freeze Frame:
                    RPM: 798 /min
                    Torque: 40.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Temperature: 3.6°C
                    Temperature: 66.6°C
                    Temperature: -37.8°C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8DA5776E8867E6AD9-806A
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 J
   Component: ClimatronicPQ35 084 0304
   Shop #: WSC 00000 000 00000
   VCID: 3D71DF7F648475F6BF5-8068
1 Fault Found:
00898 - Control Circuit A/C compressor
            010 - Open or Short to Plus
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001347143
   Coding: E1888F020004140000110D000000000000087F075C
   VCID: 3A7BD46375AA42CE9A7-806F
   Subsystem 1 - Part No: 1Z1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 73430
1 Fault Found:
01500 - Bulb for Fog-Lamps; Right (L23)
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 H    HW: 1K0 909 605 H
   Component: 08 AIRBAG VW8   023 0700
   Revision: 06023000    Serial number: 00385D0MWCHQ
   Coding: 0012344
   VCID: 3169F34FA8DC81962BD-8064
   Subsystem 1 - Serial number: 6332MSME1B6D7E07
   Subsystem 2 - Serial number: 6342MSME51087F07
   Subsystem 3 - Serial number: 6351HSME75073005
   Subsystem 4 - Serial number: 6361HSME5A513B05
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 G    HW: 1K0 953 549 G
   Component: Lenksäulenmodul 021 0050
   Coding: 0002042
   VCID: 3663C05341B2A6AE7EF-8063
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: Lenkradmodul    006 0050
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 841 D
   Component: KOMBIINSTRUMENT VD1 0914
   Coding: 0003101
   Shop #: WSC 62490 995 177229
   VCID: 377DCD5746B85FA6659-8062
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104B1103C9
   Coding: 3D3F4340071302
   Shop #: WSC 03340 411 13036
   VCID: 29591B2F800CF956E3D-807C
1 Fault Found:
01332 - Door Control Module; Passenger Side (J387)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 107
                    Reset counter: 27
                    Mileage: 195090 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:40:17
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 0914
   Shop #: WSC 03340 411 88284
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0165
   Coding: 0000118
   VCID: F4E7BA5B974E74BE00B-80A1
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.2       1502
   VCID: 306FF64BA3D6889E243-8065
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 18F802007F2D8505084F010004
   VCID: 7BF511673A10BBC6C11-802E
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000118
   VCID: F5E1875F9C346DB6375-80A0
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 156 C    HW: 1Z0 035 156 C
   Component: Radio FO3       019 0034
   Revision: 00019000    Serial number: SKZ7Z4F0006046
   Coding: 0040400
   VCID: 326BFC43ADDABA8E527-8067
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0219
   Coding: 0000048
   VCID: 2F6DF537BEE897663D9-807A
Address 69: Trailer        Labels: 8P0-907-383.lbl
   Part No SW: 8P0 907 383     HW: 8P0 907 383
   Component: ANHAENGERELEKTR H01 0010
   Coding: 0000001
   VCID: F6E38053813266AE3EF-80A3
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
End   ---------------------------------------------------------------------
Offline ro0ter
  • Mesaje postate: 76
  • Diag free forum-istilor din CjN (cand pot) >> PM
  • Auto: O2 2.0TDI BKD16V103KW140CP2007
« Răspuns #128 : Decembrie 18, 2013, 10:13:43 a.m. »
Ce nu sunt eu impacat: de peste un an de zile motorul tremura de nebun la oprire. Dar respectiva eroare (Emissions Workshop) mi-a aparut abia de o saptamana si ceva. Ce treaba are deci tremuratul cu mesajul acela de eroare n-am habar. Dupa mine mi se pare ca nu are nici au clin nici in maneca una cu alta....
Edit: "de peste un an de zile" - adica nu mai imi aduc aminte de cand, probabil chiar de cand am luat-o...
Domnilor, ma simt dator cu un raspuns. Vinovata era clapeta de aer (care are datoria ca la oprirea motoarelor diesel sa opreasca alimentarea cu aer, astfel cilindrii sa nu aiba ce copmresa cand turatia e mica aka la oprire, deci datoria ei era eliminarea tremuratului motoarelor diesel). Ardea in continuu siguranta "clapeta aer + ventilator clima + ventilator radiator" iar cand siguranta era arsa aparea rapid martorul in bord. Dupa inlocuirea sigurantei martorul ramanea (era scris in eeprom, nu in ceva ram de scurta/lunga durata, nu se resetase nici cand am luat fosta baterie la redresat), era necesara confirmarea si eliminarea alarmei prin vag-com. Dupa operatiunea cu vag-com-ul martorul ramanea oprit pana se ardea din nou siguranta.
Am desfacut pana la urma dracia aia de clapeta de aer si un motor johnson&johnson (cu perii, axul lung pe partea periilor) era cam parlit (o perie avea arcul rupt de la caldura)... L-am reparat, l-am testat, functioneaza binisor, dar de peste 6 luni nu am ansamblat-o inapoi (lol, prea mult timp liber :D). O voi testa de curiozitate in intreg ansamblul, sa nu cumva sa fie ceva logica dusa care sa o fi comandat pana dupa panzele albe :). Oricum, erau ceva bobite de cositor prin motor al caror loc nu e pe acolo, poate ele au blocat angrenajul ori motorasul.. nu aveau de unde sa iasa, am inspectat destul de bine mizeria.
900 lei mai tarziu motorul nu mai tremura. Plus manopera, bineinteles.
V`am salutat!
Skoda Octavia 2 Limousine, Elegance, 2007 2.0 TDI 140CP BKD 16V, cumparata 01.2010@165k, 199k@2013, 220k@2015, 265k@2017, 5.5/ext, 7-8/oras, 9-12+/semafoare; toarce ca un pisic si e respectata: fara tunning/folii // repar chei ;)
« Răspuns #127 : August 21, 2013, 06:43:33 p.m. »
fac pariu ca tot ceva fir/racord e de vina si aici daca a umblat cu tamponul ala motor dus atata timp
« Răspuns #126 : August 21, 2013, 05:48:31 p.m. »
Ce bine :) Drum bun !
Offline Darius31TM
  • Locaţia: Tinisoara
  • Mesaje postate: 13
  • Auto: octavia 1.9tdi 105cp
« Răspuns #125 : August 21, 2013, 05:02:40 p.m. »
Multumesc inca odata. Am rezolvat . Problema era electrica ,adica un fir care ducea la distribuitorul de vacuum era taiat din cauza frecarii intrun element al caroseriei, mersul motorului s-a schimbat in bine.Acum pot pleca in concediu linistit.
« Ultima Modificare: August 21, 2013, 05:12:15 p.m. de M i c u t z u »
Offline Darius31TM
« Răspuns #124 : August 21, 2013, 12:39:27 p.m. »
atasez o poza informativa, distribuitor vacuum care are pe stanga furtunase cu vacuum iar unul intre ele duce la EGR ,iar in partea dreapta are o mufa cu pini (mulfa electrica) care probabil printrun fir primeste de undeva comanta cand sa inchida sau deschida valva EGR
« Răspuns #123 : August 21, 2013, 11:55:54 a.m. »
Tu denumesti distribuitor de vacuum supapa N80 ?
Offline Darius31TM
« Răspuns #122 : August 21, 2013, 11:06:51 a.m. »
Buna. Revin cu noutati cazul meu pot spune asa , pentru semnalizarea emission workshop este cauzata de probleme electrice, dece spun asta ? 1. Schimbat EGR , eroarea a reaparut.2. Schimbatsenzor debitmetru , eroarea a reaparut.3.verificare partea vacuumatica , egr-ul nu primea vacuum in cazul meu deloc, iar aici este adevatatul mister .Cauza adevaratului mister este distribuitorul de vacuum care functioneaza a fost demontat si incercat pe alta masina iar cel de pe masina proba montat pe masina mea care la randul lui nu functiona.Problema este electrica distribuitorul nu primeste comanda cand sa trimita vaccum si cand nu.Ati mai intalnit asa ceva? Daca da unde trebuie sa caut? Oricum eroarea asta enervanta are foate multe probleme care trebuie descoperite.acum am schimbat piese care nu trebuiau schimbate le voi tine de rezerva
« Răspuns #121 : August 19, 2013, 04:21:57 p.m. »
Da, nu mi-o venit in cap sa-ti spun de vacuum, corect. Cu placere.
Daca la capatul furtunasului spre EGR nu masori 0,8 bar, atunci fisura e pe traseu undeva !
Offline Darius31TM
« Răspuns #120 : August 19, 2013, 04:10:08 p.m. »
AVATAR si al bundy mersi ..... am pus masina pe test si imi indica doar EGR-ul cod eroare P0401 flux prea mic ....am masurat fluxul vacummatic .... se pare ca problema EGR-ului este aceasta, nu primeste vacumm .... a masurat pompa vacummatica care avea 0.85 indicator....a verificat si distribuitorul (cutiuta neagra) cu capacul scos (cel cu furtunase multe) si scoate vacumm fiecare gaurica .... se pare ca un furtunas e spart sau fisirat ...maine las masina sa cerceteze de la pompa vacummatica pana la valva EGR ....si cand termin cu masina am sa postez un matrerial cu toate etapele si probleme....multumesc inca odata celor care m-au ajutat cu informatii....
Te rog sa nu mai folosesti in posturile viitoare atatea puncte. Punctul simplu si virgula sunt suficiente in formularea unei propozitii sau fraze.
« Ultima Modificare: August 20, 2013, 12:06:19 a.m. de FDR »
Offline Darius31TM
« Răspuns #119 : August 19, 2013, 12:58:15 p.m. »
mersi de indrumare ....... se pare ca e vacummul .....am pornit masina am scos furtunul de la vacummul EGR-ului si nu se simte nimic....am sunat mecanicul si a zis la ora 15 sa maduc sa masoare fluxul vacummatic......masurarea se face pe loc la relantiu si in mers sau pe loc si o turezi ....vacummul lucreaza tot timpul sau doar la anumite turatii...? dar vacummul respectiv ce piesa il face .... panoul (cutiuta neagra) are mai multe furtunase de vacumm ... ala are rol de distribuitor ...sau?
« Ultima Modificare: August 19, 2013, 01:35:18 p.m. de Darius31TM »
« Răspuns #118 : August 18, 2013, 09:17:57 p.m. »
Eroarea de la MAF e legata de cea de flux gaze recirculate prea mic. Verifica daca ai suficient vacuum pe furtunul de la egr.
Offline Darius31TM
« Răspuns #117 : August 17, 2013, 02:20:34 p.m. »
faza e ca am stat langa mecanic sa vad ce face.... pe calculator .... dar mare lucru nu am vazut......piesele au fost schimbate pe rand ....deci trebuie adaptate sau reglate intrun fel.....problema nu poate fi din alta parte ...deci tot aici tre sa insist .... mentionez ca nu sa schimbat cu nimic mersul motorului merge ca inainte de a se aprinde bebul emission workshop
« Ultima Modificare: August 17, 2013, 02:23:01 p.m. de Darius31TM »
« Răspuns #116 : August 17, 2013, 02:12:43 p.m. »
Apar la acelasi nr km si au frecventa 1, sunt aparute DUPA inlocuirea celor doua (EGR + MAF) ?
Daca da, ai spus ca or fost inlocuite pe rand...
Daca decuplezi MAF-ul masina merge mai prost ?
Citeste valorile pt EGR, MAF si turbo - log in mers treapta a 3a de la 1750 la 4000rpm, sa avem o imagine mai buna...
« Ultima Modificare: August 17, 2013, 02:15:28 p.m. de A V A T A R »
please help de M i c u t z u
Re: please help de vizitator
please help de castelan
Aprilie 2026
13 14 15 16 17 18 19
27 28 [29] 30
