Autor Subiect: Intreruperi intre 2000-3000 ture  (Citit de 5754 ori)
Offline manatolii
  • Mesaje postate: 149
  • Membru SK
  • Auto: Octavia 1U 1.6
Re: Intreruperi intre 2000-3000 ture
« Răspuns #7 : Aprilie 14, 2014, 01:36:22 p.m. »
Si la mine face la fel, dar stiu ca trebuie sa schimb sondele Lamda pe ambele. Poate fi si senzorul de la avans.
« Răspuns #6 : Aprilie 14, 2014, 12:11:21 a.m. »
Din ce stiu AVU are MAP
Da, este corecta afirmatia ta.
Marius, documentatia:
1,6ltr75kW,Engine,Fuelinjectionandignitionsystem,Ed.06.01,AVU,BFQ
Ai tot ce doresti, inclusiv ce trebuie sa verifici pentru eroarea respectiva.
Offline mariuscrintea
  • Locaţia: Campina
  • Mesaje postate: 4
  • OCTAVIA 1,6 AVU
  • Auto: Skoda Combi 1,6i
« Răspuns #5 : Aprilie 14, 2014, 12:00:40 a.m. »
Din ce stiu AVU nu are MAF ci MAP, ma contrazice cineva? Careca, tu ai AVU...
Revin cu intrebarea: testele readiness sunt toate parcurse sau nu? Daca nu, care nu trece testul ?
Am dat autoscan :
O sa incerc si readiness si atasez rezultatul, ok ?
Mersi !
 Tuesday,08,April,2014,16:05:42:37412
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 1U - Skoda Octavia I
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
VIN: TMBHX21U222565983   Mileage: 134820km/83773miles
Address 01: Engine        Labels: 06A-906-033-AVU.lbl
   Part No: 06A 906 033 K
   Component: SIMOS33 1,6l 2VG00HS3553
   Coding: 00031
   Shop #: WSC 31480
   VCID: 27578A38ED2D
   TMBHX21U222565983     SKZ7Z0A1107508
No fault code found.
Readiness: 1010 1101
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0013313
   Shop #: WSC 00011 000 00000
   VCID: 32616B6CD6EF
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605
   Component: 0L AIRBAG VW51 0B     02
   Coding: 12364
   Shop #: WSC 31480
   VCID: E1C354204389
Address 17: Instruments        Labels: 1U0-920-xxx-17.lbl
   Part No: 1U0 920 811 B
   Component: KOMBI+WEGFAHRSP VDO V04
   Coding: 19113
   Shop #: WSC 31480
   VCID: 2D5B7810CFD1
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 31480
   VCID: F0E521649863
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 A
   Component: 4H Komfortgerát HLO 0003
   Coding: 00067
   Shop #: WSC 31480
   VCID: 356B50702781
   Subsystem 1 - Part No: 1U4959801D
   Component: 4H Tõrsteuer.FS KLO 0002
   Subsystem 2 - Part No: 1U4959802D
   Component: 4H Tõrsteuer.BF KLO 0002
Address 56: Radio        Labels: None
   Part No: 1U0 035 160 B
   Component:  Radio              0006
   Coding: 00401
   Shop #: WSC 31480
   VCID: 27578A38ED2D
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
End   ---------------------------------------------------------------------
OCTAVIA 1,6 AVU
« Răspuns #4 : Aprilie 13, 2014, 09:45:49 p.m. »
  • Locaţia: Campina
  • Mesaje postate: 4
  • OCTAVIA 1,6 AVU
« Răspuns #3 : Aprilie 13, 2014, 09:06:11 p.m. »
Salut tuturor !
Cred ca am mai scris despre asta,dar am date noi si revin cu problema mea !
Simptome aparute de cca 3 luni / 7000 km :
1. Consum marit cu 1,5 L / 100, adica aveam mediu 7,3, extra urban 6,5 si urban   8,2. Acum mediu 8,8, extraurban 8,2, urban 10.
2. Uneori apare eroarea
Tuesday,08,April,2014,15:33:23:37412
Control Module Part Number: 06A 906 033 K
  Component and/or Version: SIMOS33 1,6l 2VG00HS3553
           Software Coding: 00031
            Work Shop Code: WSC 31480
           Additional Info: TMBHX21U222565983     SKZ7Z0A1107508
                      VCID: 27578A38ED2D
1 Fault Found:
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
        P1176 - 35-00 -  -
Readiness: 0000 0000.
Desi am schimbat sonda, eu inteleg B1 O2 ca fiind cea dupa catalizator, am verificat eventuale problem-aer fals, am curatat clapeta acceleratie, filtru aer nou, bujii noi, fise OK.....
si
3. Uneori intrerupe la turatii 2000-3000 cand merg la pas si o simt parca e gatuita...
Ma gandesc acum doar la ceva probleme
Filtru benzina, oricum schimbat acum 4 luni -12000 km
Catalizator
Sonda 1 inainte de catalizator, etc
Va rog, nu fac pe mecanicul, dar e destul de ciudat comportamentul masinii si vreau doar sa rezolv.
Aaaaa ! uneori cand sunt in traffic si o scot din viteza ,coboara acul la relanti 672, urca ca un zvac la 1200-1300 si revine la normal..Chiar nu stiu ce simptoma e asta.
In sfarsit, daca aveti ceva sfaturi, recomandari, va multumesc anticipat !
OCTAVIA 1,6 AVU
« Răspuns #2 : Martie 05, 2014, 09:52:41 a.m. »
Erori stocate sunt pe Engine?
Testele Readiness is "Complete" sau sunt si nerealizate?
  • Locaţia: Campina
  • Mesaje postate: 4
  • OCTAVIA 1,6 AVU
« Răspuns #1 : Martie 05, 2014, 09:13:54 a.m. »
Am Octavia Combi 1,6 AVU. Am problema ca intre 2000 si 3000 de ture in sarcine intrerupe motorul !
Am schimbat bijiile, bobine de inductie, sonda lambda 2 si tot asa face. Stie cineva ce sa mai verific ?
Multumesc !
OCTAVIA 1,6 AVU
please help de M i c u t z u
Re: please help de vizitator
please help de castelan
13 14 15 16 17 18 19
20 [21] 22 23 24 25 26
