Autor Subiect: Cod eroare "Abgas Werkstatt" - ma poate ajuta cineva ???  (Citit de 42468 ori)
Re: Cod eroare "Abgas Werkstatt" - ma poate ajuta cineva ???
« Răspuns #14 : August 23, 2013, 11:56:00 a.m. »
fa-i o scanare si posteaza codurile de eroare gasite
Offline ionutzz
  • Locaţia: gorj
  • Auto: skoda octavia
« Răspuns #13 : August 23, 2013, 11:37:11 a.m. »
Am skoda octavia 2 mot 2.0 140 hp
Am mers intro seara cu ea ..pe zi am facut km 250 km ....totul prfect
Apoi am oprit la cineva la poarta si..cand am pornit poc becu (robinet) sa aprins
Si pe bord zice "abgas werkstatt" o idee? Ce are si cat costa?
« Răspuns #12 : Ianuarie 26, 2010, 11:38:08 p.m. »
Ce zice manualul:
Fuel Temperature Sensor G81
The FuelTemperature Sensor G81 is located in the fuel return line between thefuel pump and the fuel cooler. It determines the current temperature ofthe fuel at that point.
The Fuel Temperature Sensor G81 has anegative temperature coefficient. The sensor resistance decreases withincreasing fuel temperature.
Signal application
The signalgenerated by the Fuel Temperature Sensor G81 is used by the DieselDirect Fuel Injection Engine Control Module J248 to determine the fueltemperature.
This signal is needed to calculate the start ofinjection point and the injection quantity so that allowance can bemade for the density of the fuel at different temperatures.
This signal is also used to determine the timing for switching on the fuel cooling pump.
Effects of signal failure
Inthe event of Fuel Temperature Sensor G81 signal failure, the DieselDirect Fuel Injection Engine Control Module J248 calculates asubstitute value from the signal generated by Engine CoolantTemperature Sensor G62.
Daca nu functioneaza corect, pe langa faptul ca nu se face racirea motorinei si se ajunge ca motorina din rezervor sa saincalzeasca ladrumuri lungi, ECU nu poate compensa pentru modificarea densitatii motorinei prin incalzire si deci avansul si cantitatea injectata nu pot fi corectate. Rezulta ca masina va consuma mai mult, deoarece ECU va injecta mai multa motorina pentru a compensa vascozitatea mai mare a motorinei, pentru care primeste informatii ca este rece...
Offline bh10mjr
  • Locaţia: ORADEA
  • Auto: SKODA SUPERB 1.9 TDI
« Răspuns #11 : Ianuarie 26, 2010, 11:18:44 p.m. »
Ledul care se aprinde este cel de la chek (cel galben)... si nu sta aprins intotdeauna.... sunt momente cand se aprinde.... sunt momente cand nu....
Masina porneste de fiecare data dar cand ramane pornit mai scoate un suntet de atentionare....
si la mine are aceleasi simptome, cu precizarea ca masina merge perfect in rest.
trage bine si nu am alte probleme cu ea.
puteti sa imi spuneti unde este acel senzor de temperatura al motorinei?
Offline sport cma
  • Locaţia: CONSTANTA
  • Mesaje postate: 7
« Răspuns #10 : Martie 03, 2009, 11:40:23 a.m. »
unde se afla pozitionat senzorul de turatie la octavia 2 1,9 tdi? defectiunea lui ma poate trimite in computer motor defect? Totusi de ce uneori functioneaza perfect motorrul?
Octavia II , motor 1,9 tdi , 2005 , gri sobolan
« Răspuns #9 : Ianuarie 11, 2009, 05:35:31 p.m. »
Orice senzor poate fi diagnosticat.  :082:
Offline RRS
  • Locaţia: CJ
  • Mesaje postate: 2935
  • Fotograf Youtubar
  • Auto: Karoq TDI
« Răspuns #8 : Ianuarie 10, 2009, 05:55:47 p.m. »
Cat a costat? Poti face singur inlocuirea?
De fapt, cum iti dai seama ca e stricat, arata pe VagCom, sau...?
merci
PS - rog pe cine stie sa posteze...
Offline alexyss
  • Locaţia: Craiova - Dolj
  • Mesaje postate: 4
« Răspuns #7 : Ianuarie 07, 2009, 09:09:27 p.m. »
Rezolvat in cele din urma : Senzorul de temperatura al motorinei era de vina
L-am schimbat si nu mai am probleme...
Offline Calin
  • Mesaje postate: 656
« Răspuns #6 : Iunie 13, 2008, 11:09:50 a.m. »
0740775867 - costi
Baiatul este din Craiova. Suna-l, are Vag si te poate ajuta. Daca te intreaba ii zici ca numarul il ai de la Gabi, un forumist :)
Asta-i motivul pentru care te-am pus sa zici locatia si pe viitor am o rugaminte la toti userii, rugaminte care poate fi preluata de moderatori si introdusa in regulament: PUNETI LOCATIA DE UNDE SUNTETI IN PROFIL!
Astfel va putem ajuta mai usor cu problemele voastre.
Offline alexyss
  • Mesaje postate: 4
« Răspuns #5 : Iunie 13, 2008, 09:16:43 a.m. »
Este motor Diesel 1.9 dintr-asta nou de se gaseste si pe noul passat sau Golf 5.
Am impresia ca este de la evacuarea gazelor din esapament pt ca am mai vb cu cineva si mi-a zis sa merg cu ea mai turata ca sa se atinga o anumita temperatura in catalizator (sa merg peste 2000 - 2500 rot/min)...
Eu mergeam de obicei pe la 1500 - 1700 Rot/min.
PT c4linutz - sunt din Craiova
MULTUMESC TUTUROR CELOR CARE AU POSTAT - CREDEAM CA NU MA VA AJUTA NIMENI
GOOD FORUM
« Ultima Modificare: Iunie 13, 2008, 09:18:18 a.m. de alexyss »
« Răspuns #4 : Iunie 08, 2008, 09:32:55 a.m. »
daca e diesel,am patit si eu asa.imi dadea emissions-workshop.am constatat ca senzorul de temp motorina era defect.mai precis era un fir rupt. iar masina mergea prost.nu mai tragea cum trebuie.mai ales la accelerari puternice.ia vezi daca este asa.
« Răspuns #3 : Iunie 08, 2008, 12:22:31 a.m. »
Daca s-a aprins martorul galben ca un robinet, este vorba de emisii... Deci?
Offline Calin
« Răspuns #2 : Iunie 07, 2008, 04:11:57 p.m. »
Salut. Ce bec iti ramane aprins in bord? Masina nu mai porneste deloc? Abgas - inseamna gaze de evacuare si Werkstatt inseamna atelier. Cred ca ai o problema pe evacuare si te trimite la service. Da-ne mai multe detalii despre masina: motor, an, model masina.. si de unde esti poate te ajutam cu ceva. Nu poti seta meniul in Engleza?
Offline alexyss
  • Mesaje postate: 4
« Răspuns #1 : Iunie 07, 2008, 03:08:24 p.m. »
Am de curand o octavia 2 din 2006 si de ceva vrema imi da o eroare la pornire si ramane becul de la bord aprins. Mesajul este "Abgas Werkststt"...
Puteti sa-mi spuneti despre ce este vorba si cat de grava este problema ???
