va rog sa ma ajutati si pe mine cu citirea unor coduri am o skoda 1,6 din 98 si in urma scanari am gasit urmatoarele defecte,eu nu ma pricep dar daca ma duc la un servis sigur baga pe git altele si nu face masina pe cit imi cer.multam
VCDS Version: Release 908.0
Data version: 20090911
Sunday,31,January,2010,10:25:14:20955
Chassis Type: 1U - Skoda Octavia I
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
Mileage: 130760km/81250miles
Address 01: Engine Labels: Redir Fail!
Part No: 032 906 014 E
Component: MARELLI 1AVM 2177
6 Faults Found:
00522 - Engine Coolant Temperature Sensor (G62)
29-10 - Short to Ground - Intermittent
00525 - Oxygen (Lambda) Sensor (G39)
07-10 - Signal too Low - Intermittent
00516 - Closed Throttle (Idle) Position Switch (F60)
27-10 - Implausible Signal - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
31-10 - Open or Short to Ground - Intermittent
00282 - Throttle Position Actuator (V60)
36-10 - Open Circuit - Intermittent
Readiness: N/A
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 603 AT
Component: AIRBAG VW3 - V04
Coding: 16724
Shop #: WSC 00064
3 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
33-10 - Resistance too Low - Intermittent
32-10 - Resistance too High - Intermittent
00532 - Supply Voltage B+
Address 17: Instruments Labels: 1Ux-919-xxx-17.lbl
Part No: 1U1 919 033 L
Component: A+-KOMBIINSTR. VDO V08
Coding: 02142
Shop #: WSC 31480
Part No: IMMO
Component: IDENTNR: SKZ7Z0V0051132
IMMO-IDENTNR: SKZ7Z0V0051132
No fault code found.
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 L
Component: 0W Zentral-SG Komf.0002
Coding: 04097
Shop #: WSC 31480
Part No: 1U4959801A
Component: 0W Tõrsteuerger. FS0022
Part No: 1U4959802A
Component: 0W Tõrsteuerger. BF0022
Part No: 1U0959811A
Component: 0W Tõrsteuerger. HL0022
Part No: 1U0959812A
Component: 0W Tõrsteuerger. HR0022
7 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00912 - Window Regulator Switch; Front Left (E40)
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
00934 - Electric Window Motor; Rear Left (V26)
62-00 - No or Incorrect Adjustment
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
00935 - Electric Window Motor; Rear Right (V27)
62-10 - No or Incorrect Adjustment - Intermittent
00931 - Locking Module for Central Locking; Rear Right (F223)
End ---------------------------------------------------------------------
