Autor Subiect: coduri erori vag  (Citit de 417185 ori)
Offline dodobird
  • Mesaje postate: 481
Re: coduri erori vag
« Răspuns #88 : Februarie 27, 2009, 11:09:43 a.m. »
In principiu nu deranjeaza decat lipsa informatiei respective (vezi mai jos). Totusi daca este doar o problema de cupla/legaturi merita facuta , daca este chiar senzorul asta probabil costa ceva mai mult.
  00779 - Outside Air Temperature Sensor (G17)    00779 - Outside Air Temperature Sensor (G17): Open or Short to Plus    Possible Symptoms
  • In the Instrument Cluster you see dashes (---) instead of a temperature
   Possible Causes
  • Wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster: Open or Short Circuit
   Possible Solutions
  • Check wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster
  • Check Measuring Block Value
    00779 - Outside Air Temperature Sensor (G17): Short to Ground    Possible Symptoms
   Possible Causes
  • Outside Air Temperature Sensor (G17) damaged
   Possible Solutions
  • Check / Replace Outside Air Temperature Sensor (G17)
Offline kryss782001
  • Locaţia: GIURGIU
  • Mesaje postate: 99
« Răspuns #87 : Februarie 25, 2009, 09:38:12 p.m. »
salut, am testat si eu fabiuta si am gasit eroarea asta(este senzorul temp exterioara nu?)Fault Found:
00779 - Outside Air Temp Sensor (G17)
            30-00 - Open or Short to Plus, daca nu functioneaza este vreo problema?multumesc
fabia 1,4 16v 75hp 2005
« Răspuns #86 : Ianuarie 19, 2009, 10:51:06 p.m. »
Da, tb calibrata clapeta cu VAG-ul...dureaza putin.
Offline slvzma
  • Mesaje postate: 6
« Răspuns #85 : Ianuarie 19, 2009, 08:25:04 p.m. »
ok. mersi
Offline C o s m i n
  • Mesaje postate: 5853
  • ZEN Master
  • Auto: Fabia 287 Nm
« Răspuns #84 : Ianuarie 19, 2009, 08:16:03 p.m. »
Ai nevoie de vag com, si de cineva care sa stie sa faca adaptarea clapetei.
Offline slvzma
  • Mesaje postate: 6
« Răspuns #83 : Ianuarie 19, 2009, 07:12:02 p.m. »
resoftare la clapeta. cum fac asta?
Offline slvzma
  • Mesaje postate: 6
« Răspuns #82 : Ianuarie 19, 2009, 05:14:01 p.m. »
ok mersi...dar am inteles ca dupa curatarea clapetei..trebuie sa ii fac ceva dar nu stiu ce si cum sa fac...?
« Răspuns #81 : Ianuarie 19, 2009, 04:38:08 p.m. »
1- curata clapeta acceleratie
2- verifica furtunasele, sa nu ai aer fals
Offline slvzma
  • Mesaje postate: 6
« Răspuns #80 : Ianuarie 19, 2009, 03:08:30 p.m. »
salut...am si eu o skoda 1.8t 150cp aum ....si am o problema.."imi da in nas" cand o accelerez usor... pe tester imi da MAf signal too low am schimbat vreo 2 debitmetre si tot la fel merge ce ar  putea fi...?
« Răspuns #79 : Ianuarie 14, 2009, 10:47:20 a.m. »
rata de recirculare a EGR se reduce sub 5% (ca si acceleratie) daca motorul sta la ralanti mai mult de 1 minut
Offline GTI paua
  • Locaţia: Cj
  • Mesaje postate: 641
« Răspuns #78 : Ianuarie 10, 2009, 11:28:58 p.m. »
...never...
Offline RRS
  • Locaţia: CJ
  • Mesaje postate: 2935
  • Fotograf Youtubar
  • Auto: Karoq TDI
« Răspuns #77 : Ianuarie 10, 2009, 07:25:27 p.m. »
Credeti ca daca se sta cu masina pornita dimineata cca. 10 minute cateva zile, e motiv sa se infunde EGR?
Offline GTI paua
  • Locaţia: Cj
« Răspuns #76 : Decembrie 28, 2008, 08:51:18 p.m. »
....La capatul tevii care intra in galeria de admisie ( sub clapeta aer ) erau 2 orificii complet infundate. Era un fel de noroi ( praf + ulei ).
 :D semn ca motorasul ala nu a prea avut parte de reprize la 4000+ rpm ,pentru desfundat "nasucul".Este de avut in vedere asa ceva . ;)
Offline ValentinC
  • Mesaje postate: 11
« Răspuns #75 : Decembrie 28, 2008, 02:19:09 p.m. »
Revin cu rezolvarea problemei mele ...
Dupa ce am schimbat supapa EGR cam la 25 km s-a aprins iarasi becu  @-).
Eroare aparuta : idem ( insuficient flow )
Dupa normalele lovituri cu tesla .... am purces la rezolvarea problemei babeste.
Adica am desfacut tot traseul EGR si am constatat cu surprindere ca problema era f simpla.
La capatul tevii care intra in galeria de admisie ( sub clapeta aer ) erau 2 orificii complet infundate. Era un fel de noroi ( praf + ulei ). Dupa curatare si suflare cu aer  nu am mai avut nici o prblema.
Intre timp am mai intalnit 2 Skode Fabia cu aceiasi problema.
Asa ca mare atentie inainte sa investiti intr-o noua supapa EGR.
Salutari si La Multi Ani
Offline iulian325
  • Locaţia: IASI
  • Mesaje postate: 70
« Răspuns #74 : Noiembrie 30, 2008, 02:09:16 a.m. »
pt inceput sa ma documentez:
Exhaust gas recirculation (egr) is a nitrogen oxide (NOx) emissions reduction technique used in most gasoline and diesel engines.
http://en.wikipedia.org/wiki/EGR_valve
http://video.google.com/videoplay?docid=1033257113351316860
asta e belea :
http://it.youtube.com/watch?v=AMPzu6-i6ik&feature=related
22 23 [24] 25 26 27 28
