Autor Subiect: coduri erori vag  (Citit de 402501 ori)
Offline RRS
  • Locaţia: CJ
  • Mesaje postate: 2935
  • Fotograf Youtubar
  • Auto: Karoq TDI
Re: coduri erori vag
« Răspuns #193 : Februarie 28, 2010, 10:49:37 p.m. »
...daca am grija de ea :)
ammai sters eroarea cu bujia si am mai miscat fisele,si nu a mai aparut...
e ciudata pe 4, insa in limite...
Offline radioman
    • Radio Romania Constanta
« Răspuns #192 : Februarie 28, 2010, 09:59:54 p.m. »
In afara de cilindrul 4 unde mi-se pare ciudata rau valoarea aia de corectie, se pare ca nu sunt probleme..
Pe grupul 13 insa  valorile de corectie sunt enervant de bune..
« Ultima Modificare: Februarie 28, 2010, 10:03:00 p.m. de radioman »
Offline RRS
  • Locaţia: CJ
  • Fotograf Youtubar
  • Auto: Karoq TDI
« Răspuns #191 : Februarie 28, 2010, 03:30:08 p.m. »
imi pare ca la injectorul 4 e cam mica valoarea... cu bujie dusa pe 3 :D  teste facute pe loc la 2000rpm
Sunday,28,February,2010,13:16:10:63170
VCDS Version: Release 908.0
Data version: 20090830
                Address 01: Engine  (03G 906 016 DJ)
13:15:33 Group 001: Injection Quantity
  1911 /min  Engine Speed (G28)
  6.6 mg/str  Injection Quantity
  5.1°KW  Injection Duration (specified)
  42.3°C  Coolant Temperature (G62)
13:15:33 Group 010: Charge Pressure Control
  275.0 mg/str  Mass Air Flow (actual)
  958.8 mbar  Atmospheric Pressure
  1060.8 mbar  Boost Pressure (actual)
  17.3 %  Accel. Pedal Pos. Sensor 1 (G79)
13:15:33 Group 013: Idle Stabilization (Injection Quantity Deviation)
  -0.31 mg/str  Injection Quantity Deviation Cyl. 1
  0.85 mg/str  Injection Quantity Deviation Cyl. 2
  -0.40 mg/str  Injection Quantity Deviation Cyl. 3
  -0.12 mg/str  Injection Quantity Deviation Cyl. 4
Sunday,28,February,2010,13:18:24:63170
13:18:13 Group 001: Injection Quantity
  819 /min  Engine Speed (G28)
  4.9 mg/str  Injection Quantity
  6.1°KW  Injection Duration (specified)
  49.5°C  Coolant Temperature (G62)
13:18:13 Group 013: Idle Stabilization (Injection Quantity Deviation)
  -0.28 mg/str  Injection Quantity Deviation Cyl. 1
  0.24 mg/str  Injection Quantity Deviation Cyl. 2
  -0.02 mg/str  Injection Quantity Deviation Cyl. 3
  0.07 mg/str  Injection Quantity Deviation Cyl. 4
13:18:13 Group 023: Injector Switch Time Deviation
  -29.0  Switch Time Deviat. Cylinder 1
  -22.0  Switch Time Deviat. Cylinder 2
  -32.0  Switch Time Deviat. Cylinder 3
  -6.0  Switch Time Deviat. Cylinder 4
Offline radioman
« Răspuns #190 : Februarie 28, 2010, 09:33:22 a.m. »
Scrie chiar sub fereastra valorile normale, in general intre -2 si + 2..
Offline RRS
  • Locaţia: CJ
  • Fotograf Youtubar
  • Auto: Karoq TDI
« Răspuns #189 : Februarie 27, 2010, 09:27:43 p.m. »
care sunt valorile normale?cred ca ar fi semnalat ca e vreun bai la injectie, si sigur dadea masina ceva semne in mers...
« Răspuns #188 : Februarie 27, 2010, 09:20:31 p.m. »
Exact, asta spuneam cu valorile.
O valoare inafara gamei la un injector iti spune ca este defect.
Bujiile cu incandescenta pica cand pica...poate cea de anul trecut nu era a 3-a.
Offline RRS
  • Locaţia: CJ
  • Fotograf Youtubar
  • Auto: Karoq TDI
« Răspuns #187 : Februarie 27, 2010, 09:16:41 p.m. »
mi-au schimbat in service in august doar una, ca era arsa... :)
nu functioneaza injectorul?
cand zici 1 zici modul Engine si 13, 14, 15 sunt module in measuring blocks?
« Răspuns #186 : Februarie 27, 2010, 09:12:19 p.m. »
Da, bujia 3 este dusa... poti verifica si injectoarele pe [01] > 013, 014, 015.
Offline RRS
  • Locaţia: CJ
  • Fotograf Youtubar
  • Auto: Karoq TDI
« Răspuns #185 : Februarie 27, 2010, 08:57:58 p.m. »
am o bujie arsa? am sters si de ieri pana azi a aparut din nou eroarea...
ieri:
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
            P0673 - 000 -  -
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 246.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.86 V
                    Bin. Bits: 00000100
                    Temperature: -11.7°C
                    Bin. Bits: 00110000
AZI
            Work Shop Code: WSC 66565 257 00032
1 Fault Found:
            P0673 - 000 -  -
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 154.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.08 V
                    Bin. Bits: 00000100
                    Temperature: 6.3°C
                    Bin. Bits: 00110000
Readiness: 0 0 0 0 0
apoi mai am alta, stearsa si reaparuta...
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0034
   Revision: 00019000    Serial number: SKZ7Z3F0068256
   Coding: 0000200
   Shop #: WSC 73430 790 00000
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
Post Merge: Februarie 27, 2010, 09:08:43 p.m.
si codurile in manual apar cu un grad intre 1-5 e mai grav... nu imi apar in autoscan... :(
« Ultima Modificare: Februarie 27, 2010, 09:08:43 p.m. de RRS »
« Răspuns #184 : Februarie 11, 2010, 01:13:12 p.m. »
pe engine, in modul 007 se citesc 3 temperaturi. ma intereseaza ce senzori "citesc" temperaturile pentru ca unul este nasol..
« Răspuns #183 : Februarie 11, 2010, 11:52:55 a.m. »
LUCI, vorbim de Engine ? Te intereseaza valorile generice sau masurate concret pe un motor anume ?
« Răspuns #182 : Februarie 11, 2010, 11:49:27 a.m. »
intrebare mare:
in vag-com, la measuring blocks, modul 007, imi poate spune cineva care sunt cele 3 temperaturi?
« Răspuns #181 : Februarie 11, 2010, 11:44:58 a.m. »
Greu de dat un verdict in km. Mai pot fi cateva mii sau nu. Un senzor are darul de a pica din senin daca vrea. Ideea este ca daca pica, de unde te vei afla, direct intr-un service (Skoda) vei ajunge. Este un risc implicit pe care daca ti-l asumi, e OK. ;)
Offline skodamar
  • Locaţia: Baia Mare
  • Auto: Octavia 1.6 Benzina
« Răspuns #180 : Februarie 11, 2010, 11:17:08 a.m. »
Nu, nu mai este în garanție. Dar nu văd sincer ce legătură are. Pentru că întrebarea mea era dacă pot să fac mulți km cu mașina cu eroarea aia, ce îmi recomandați. În rest e irelevant acum cine o să plătească senzorul ăla (dacă) trebuie înlocuit.
« Răspuns #179 : Februarie 05, 2010, 11:35:44 p.m. »
Greu de dat verdicte certe de la keyboard :)
[Azi la 05:34:00 p.m.]
[Azi la 05:21:12 p.m.]
[Azi la 01:07:59 p.m.]
Aprilie 2026
13 14 15 16 [17] 18 19
27 28 29 30
