Autor Subiect: coduri erori vag  (Citit de 402936 ori)
0 Membri şi 36 Vizitatori vizualizează acest subiect.
Re: coduri erori vag
« Răspuns #898 : Februarie 10, 2016, 02:23:01 p.m. »
Prima eroare e o "bitch" !
Citeste topicul Blue Torch - Fabia Combi SDI Comfort din aria dedicata, in perioada iarna 2014 - primavara 2015 am tratat pe larg aceasta problema.
Offline Shumi21
  • Auto: Skoda Fabia 1.4mpi
« Răspuns #897 : Februarie 10, 2016, 02:17:22 p.m. »
Salutare. Am facut setarea de baza la G85, dar acum mi-au aparut alte 2 erori si a disparut aia. Mentionez ca se sterg erorile, dar apar dupa prima frana calcata. Multumesc mult pentru ajutor.
Wednesday,10,February,2016,14:03:58:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: TMBHC26Y654292577   License Plate: IS89SIA
                Address 03: ABS Brakes       Labels: 6R0-907-37x-ESP80.lbl
Control Module Part Number: 6Q0 907 379 T    HW: 6Q0 907 379 T
  Component and/or Version: ESP 8.0 front   H03 0002
           Software Coding: 0000365
            Work Shop Code: WSC 13765 000 00000
                      VCID: 4E9388B3DA22FE6E56F-5000
2 Faults Found:
01314 - Engine Control Module
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 284731 km
                    Time Indication: 0
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 284731 km
                    Time Indication: 0
« Răspuns #896 : Februarie 10, 2016, 11:35:52 a.m. »
Nu te grabi inca cu inlocuirea EGR. Citeste aici si verifica intai:
http://www.obd-codes.com/p0403
Offline dandanb
  • Mesaje postate: 9
  • Auto: Skoda Superb II
« Răspuns #895 : Februarie 09, 2016, 11:33:47 p.m. »
 Detin un Superb 2012 2.0 TDI, 170 CP, cutie manuala, tractiune 2x4, 85000 km.
 Acum 2 luni mi s-a aprins in mers intermitent martorul de preincazire. In momentul in care era senzorul aprins masina nu avea deloc putere. Dupa repornirea motorului martorul nu s-a mai apris.
 Am facut o prima scanare de erori si nu a rezultat nici o defectiune. Dupa o perioada in care mi se tot aprindea acest martor in mod aleator la un moment dat s-a aprins si martorul de defectiune motor. Am facut din nou scanare si de data aceasta am gasit urmatoarea eroare:
 P040300 - Exhaust gas recirculation control circuit. Intermitent.
 In prezent martorul de preincalizire se mai aprinde cateodata dar ala de motor nu s-a mai aprins de atunci.
 De la Skoda Cluj mi s-a spus ca trebuie schimbat EGR-ul. Am fost sa caut cat costa piesa la cateva magazine de piese si se pare ca pentru modelul meu de Superb nu exista piesa EGR pe producator doar originara. Pentru modele de Superb mai vechi un EGR costa 650 RON, originara pentru modelul meu costa cam 1900 RON.
 Va rog sa imi dati un sfat care ar fi varianta optima in cazul acestei probleme?
« Răspuns #894 : Februarie 09, 2016, 06:01:48 p.m. »
ABS:
http://workshop-manuals.com/skoda/fabia-mk1/chassis/abs_adr_tcs_edl_esp/basic_setting__abs_systems_bosch_8.0/null_balance_of_the_steering_angle_senderg85_%28vehicles_with_abs/tcs/esp_bosch_8.0%29/
 Pentru eroarea de pe Instruments, verifica conexiunea la senzor. Daca conexiunea este in regula, trebuie inlocuit senzorul.
Offline Shumi21
« Răspuns #893 : Februarie 09, 2016, 03:26:02 p.m. »
Buna ziua dragi skodisti, de curand am intrat si eu in posesia unei Skoda Fabia din 2005 1.4 benzina 75cp, iar in urma diagnozei au rezultat urmatoarele erori. Imi poate spune cineva cum le pot rezolva va rog frumos? Si mai am o problema pe langa astea, la cilindrul 3 cand scot bobina e plin de ulei acolo, am curatat, am schimbat bujiile, dar tot reapare uleiul. In rest masina merge foarte bine, per total sunt multumit de ea. Numai bine si o zi buna!
Tuesday,09,February,2016,14:51:15:62939
Mileage: 284710km-176910mi   Repair Order:
Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBHC26Y654292577   Mileage: 284710km/176910miles
Address 01: Engine        Labels: 036-906-034-APE.lbl
   Part No: 036 906 034 JE
   Component:  MARELLI 4TV        6496
   Coding: 00071
   Shop #: WSC 77763
   VCID: 5EB378F3DAC24EEEC6F-4A3A
   TMBHC26Y654292577     SKZ7Z0E2809453
No fault code found.
Readiness: 1110 0101
   Part No SW: 6Q0 907 379 T    HW: 6Q0 907 379 T
   Component: ESP 8.0 front   H03 0002
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0000365
   Shop #: WSC 13765 000 00000
   VCID: 4E9388B3DA22FE6E56F-5072
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 62
                    Mileage: 284716 km
                    Time Indication: 0
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Y0 820 045
   Component: Klimaanlage        X0840
   VCID: F2EBBC43BE5A7A8E127-50E6
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 0000 BN-SG.         1S34
   Coding: 25786
   Shop #: WSC 13765
   VCID: 3C77D27B2C9E7CFE88B-5000
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 K
   Component: 05 AIRBAG VW51 08   0008
   Coding: 12341
   Shop #: WSC 13765
   VCID: 2C57E23BDCFEEC7E18B-5072
Address 17: Instruments        Labels: 6Y0-920-xx0-17.lbl
   Part No: 6Y0 920 881 L
   Component: KOMBI+WEGFAHRSP VDO V02
   Coding: 00101
   Shop #: WSC 13765
   VCID: 479DBD9765582F26159-5000
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
            30-00 - Open or Short to Plus
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 003G GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 00186
   VCID: F0EFB64BB056489EE43-5072
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6Q0 423 156 AA
   Component: LenkhilfeKYO        V957
   Coding: 10140
   Shop #: WSC 13765
   VCID: 6ED328332A62DE6E76F-5072
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 E
   Component: 3A Komfortgerát     0002
   Coding: 00019
   Shop #: WSC 13765
   VCID: 3D71DF7F378475F6BF5-49D8
Address 56: Radio        Labels: 1U0-035-156.lbl
   Part No: 6Y0 035 156 E
   Component:  Radio YD5          0010
   Coding: 00201
   Shop #: WSC 13765
   VCID: 387FCE6B18A650DE6C3-4918
End   ---------------------------------------------------------------------
« Răspuns #892 : Februarie 03, 2016, 12:04:11 a.m. »
01422 - Hydraulic Pump for Electronic Stability Program (V156)
            35-10 - - - Intermittent
01435 - Brake Pressure Sensor 1 (G201)
            27-10 - Implausible Signal - Intermittent
            49-10 - No Communications - Intermittent
Erorile astea 3, cumulate - daca se dovedeste ca ti-i dusa unitatea ABS (unde e si G201 ala), adunat cu G85, da o suma MARE RAU (probabil cateva zeci milioane lei). Totusi, ele reapar, odata sterse si dupa un drum cu masina ? Daca da....
Si chiar de-ai gasi la dezmembrari si TOT MARE E suma. Asa e cu Octaviile astea 2 :(
Offline #PIT
  • Mesaje postate: 365
  • Auto: O2FL 1.9TDI 77kW BXE
« Răspuns #891 : Februarie 02, 2016, 11:31:06 a.m. »
Se da urmatorul log. Cat este de grav (pentru buzunar):))
Tuesday,02,February,2016,10:13:58:62939
VIN: WVWZZZ3BXXXXXXXXXX   License Plate:
Mileage: 248380km-154336mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ1P056964   Mileage: 248380km/154336miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 DS
   Component: 1,9l R4 EDC 0000SG  1266
   Coding: 00002
   Shop #: WSC 00028
   VCID: 6BD5212719702B46511-4A9C
   WVWZZZ3BZ1P056964     VWZ7Z0Y2942859
1 Fault Found:
18057 - Powertrain Data Bus
            P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 8D0 907 389 D
   Component: ABS/ESP front       D46
   Coding: 04255
   Shop #: WSC 11111
   VCID: 3467FA5B04CEB4BE40B-5072
3 Faults Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 H
   Component: CLIMATRONIC B5GP    0002
   Coding: 17000
   Shop #: WSC 00028
   VCID: 26431013C212D62ECEF-5000
   Part No: 6Q0 909 605 C
   Component: 08 AIRBAG VW6  04   0004
   Coding: 12344
   Shop #: WSC 00028
   VCID: 377DCD5715B85FA6659-4A9C
1 Fault Found:
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 825 A
   Component: KOMBI+WEGFAHRSP VDO V10
   Coding: 05125
   Shop #: WSC 00001
   VCID: 204F060BA036381EB43-5072
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00028
   VCID: F0EFB64BB056489EE43-5000
1 Fault Found:
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 0Z Komfortgerát HLO 0001
   Coding: 00259
   Shop #: WSC 05311
   VCID: 3663C05312B2A6AE7EF-4A3A
   Subsystem 1 - Part No: 1C1959801
   Component: 03 Tõrsteuer.FS     0001
   Subsystem 2 - Part No: 1C1959802
   Component: 03 Tõrsteuer.BF     0001
   Subsystem 3 - Part No: 1C0959811
   Component: 03 Tõrsteuer.HL     0001
   Subsystem 4 - Part No: 1C0959812
   Component: 03 Tõrsteuer.HR     0001
4 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
01330 - Central Control Module for Central Convenience (J393)
            37-00 - Faulty
00928 - Locking Module for Central Locking; Front Driver Side (F220)
01359 - Internal Central Locking Switch; Passenger Side (E198)
Offline br80bby
  • Locaţia: braila
  • Auto: skoda 1.6 mpi
« Răspuns #890 : Ianuarie 30, 2016, 10:21:27 p.m. »
Multumesc, luni o s-o duc sa vad ce-mi spune. Vroiam sa stiu o parere, mecanicii iti mai schimba si ce nu ai nevoie cateodata , mai ales strain in alta tara.
« Ultima Modificare: Ianuarie 30, 2016, 11:24:36 p.m. de FDR »
« Răspuns #889 : Ianuarie 30, 2016, 06:12:04 p.m. »
Offline br80bby
  • Locaţia: braila
« Răspuns #888 : Ianuarie 30, 2016, 05:47:12 p.m. »
 A avut cineva vreodata o problema asemanatoare in urma diagnozei cu cilindri 1 si 4(nu am notat codul erorii). Simptome masina urca greu in ture , chiar foarte greu in treapta 5 , "check engine " aprins + zgomot (zumzait), mentionez ca sunt in italia si ca nu as vrea s-o repar aici, asta daca problema nu ar fi foarte grava. Alt subiect asemanator nu am gasit, asa ca am deschis unul nou. Multumesc!
Offline twopak
  • Mesaje postate: 114
  • ''membru''
  • Auto: Superb 4T L&K 150 cp
« Răspuns #887 : Ianuarie 26, 2016, 06:19:19 p.m. »
Multumesc Doru. Esti prompt ca de obicei.
In cazul meu , eroarea 000665 -boost presure regulation s-a dovedit a fi membrana actuatorului turbinei sparta( nu tine presiune). Pentru ca aveam turbina de la "pantera neagră " doar am înlocuit-o. O sa o desfac sa văd ce este înăuntru si eventual am sa o repar. Am mai găsit si axul regulatorului la racitorul de aer EGR rupt. Deasemenea am avut noroc ca am avut si acea piesa si am înlocuit-o. Acum merge ceas.
Drumuri bune tuturor !
« Răspuns #886 : Ianuarie 21, 2016, 09:47:19 a.m. »
Offline twopak
  • ''membru''
« Răspuns #885 : Ianuarie 21, 2016, 09:08:23 a.m. »
Multumesc Doru.
Am verificat si atașez rezultatul.
Problema este ca nivelul acela de cenușă nu scăzut după nici o regenerare.
Am fost la Skoda le-am spus ca mașina intra in limp mode si se aprind becurile de service si engine . Mi-au spus ca este senzorul de temperatura la ieșirea din filtru DPF. Pentru ca il aveam de pe vechea mașina L-am schimbat. Coduri diferite dar am zis ca merge . Acum imi da o alta eroare
009326 - Exhaust Gas Temperature Sensor 4 Bank 1                P246E - 000 - Electrical Malfunction - MIL ON             Freeze Frame:                    Fault Status: 11100000                    Fault Priority: 2                    Fault Frequency: 1                    Reset counter: 255                    Mileage: 143611 km                    Time Indication: 0                    Date: 2010.06.12                    Time: 18:46:09             Freeze Frame:                    RPM: 0 /min                    Speed: 0.0 km/h                    Voltage: 12.16 V                    Temperature: 46.8°C                    Temperature: 54.0°C                    Temperature: 66.0°C                    Temperature: 930.0°C
Ma ajuta si pe mine sa ii dau de cap ? De ce imi intra in limp sau ce doamne iartă ma este
Multumesc.
« Ultima Modificare: Ianuarie 21, 2016, 09:19:40 a.m. de twopak »
« Răspuns #884 : Ianuarie 17, 2016, 10:16:00 p.m. »
Masurarea incarcarii DPF:
Engine > Measuring Blocks > subgrup 108
Poti citi aici pe larg:
http://forums.tdiclub.com/showthread.php?t=324067
Aprilie 2026
13 14 15 16 17 18 [19]
27 28 29 30
