Autor Subiect: Skoda Octavia 2 DSG 1.9 TDI  (Citit de 113171 ori)
Offline murillo
  • Mesaje postate: 598
  • Auto: O2 2.0 TDI
« Răspuns #160 : Mai 07, 2012, 09:17:19 p.m. »
Te sustin, desi ar fi cea mai ieftina varianta ca ti-o remediaza gratis. Senzorul busit ar fi cea mai scumpa...
Tine-ne la curent :082:
« Răspuns #159 : Mai 07, 2012, 09:12:17 p.m. »
Mersi de diagnoza si pentru ca ai postat logurile.
Vizita la service nu mai poate fi evitata :)
Am sa le zic sa verifice in ordinea recomandata: siguranta, cablajele si conectorii si apoi senzorul.
Am sa scriu si cum s-a rezolvat problema dupa ce reusesc sa ajung la service.
L.E.: murillo, sper sa nu fie asta problema dar am sa le cer sa verifice si pozitia curelei.
Offline murillo
  • Auto: O2 2.0 TDI
« Răspuns #158 : Mai 07, 2012, 09:12:03 p.m. »
Eu zic ca e pozitia incorecta a curelei de distributie :-?
« Răspuns #157 : Mai 07, 2012, 08:51:04 p.m. »
Erorile din seara asta:
Address 01: Engine        Labels: Redir Fail!
   Part No SW: 03G 906 021 RH    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000AG  2006
   Revision: --H07---    Serial number: SKZ7Z0H4729740
   Coding: 0000078
   Shop #: WSC 66565 257 00032
   VCID: 76E9977C01DC22E
1 Fault Found:
000833 - Camshaft Position Sensor (G40)
               P0341 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 3
                    Fault Frequency: 7
                    Mileage: 110889 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:01:28
             Freeze Frame:
                    RPM: 1302 /min
                    Speed: 26.0 km/h
                    Load: 0.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 00001000
                    Idle Stabilization: -0.5°KW
                    (no units): 48.0
Readiness: 0 0 0 0 0
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0100
   Coding: 0012042
   Shop #: WSC 73430 790 00000
   VCID: 78F599440BC854E
   Part No: XXXXXXXXXXX
   Component: E0221           002 0010
4 Faults Found:
00576 - Terminal 15
            012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0191
   Revision:   H16       Serial number: 2000K07C190A84
   Coding: ED817F0E4002021302
   VCID: 346D6D74572070E
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 28
                    Mileage: 110855 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:58:05
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 28
                    Mileage: 110855 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:58:05
De data asta a dat 000833 care e putin diferit fata de 012295
Si anume de pe Ross Tech
12295 - Camshaft Position Sensor (G40): No Signal    Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
   Possible Causes
  • Fuse(s) faulty
  • Wiring and/or Connector(s) from/to Camshaft Position Sensor (G40) faulty
  • Camshaft Position Sensor (G40) faulty
   Possible Solutions
  • Check Fuse(s)
  • Check Wiring and/or Connector(s) from/to Camshaft Position Sensor (G40)
  • Check/Replace Camshaft Position Sensor (G40)
000833 - Camshaft Position Sensor (G40): Implausible Signal    Possible Symptoms
  • Malfunction Indicator Light (MIL) active
   Possible Causes
  • Wiring from/to Camshaft Position Sensor (G40) faulty
  • Timing misaligned
   Possible Solutions
  • Check Wiring from/to Camshaft Position Sensor (G40)
  • Check Camshaft Position Sensor (G40)
  • Check Timing
« Ultima Modificare: Mai 07, 2012, 09:06:08 p.m. de iwolffy »
« Răspuns #156 : Mai 07, 2012, 05:25:24 p.m. »
Mda, se pare ca iar o sa trebuiasca de dat tot jos ca sa se ajunga pana acolo.
Stie cineva daca e posibil sa nu fi facut bine lucrarea (schimbul distributiei) mecanicii si din cauza asta sa apara eroarea asta?
« Răspuns #155 : Mai 07, 2012, 05:20:57 p.m. »
Uite unde e
« Răspuns #154 : Mai 07, 2012, 05:13:10 p.m. »
Mda, o veste buna  :042:
Confirmarea mai tarziu.
Revin cu intrebarea mea: ce contacte ar trebui sa verific inainte sa schimb senzorul?
Mersi.
« Răspuns #153 : Mai 07, 2012, 04:55:09 p.m. »
Fault Frequency shows how many times the conditions that caused the fault have recurred, during all driving cycles. So, if you have a fault with a Frequency of 11,  then conditions sufficient to trigger the fault have happened 11 times since the fault was stored. The counter can have values from 0 to 254. It is incremented with each occurrence of the fault (during all driving cycles).
Deci din ce inteleg eu, iti afiseaza cand a aparut pentru prima oara eroarea, si apoi se incrementeaza de fiecare data cand mai apare. Apare 254 pentru ca asta este maximul.
« Răspuns #152 : Mai 07, 2012, 04:18:57 p.m. »
Azi ar trebui sa aflu daca a aparut si s-a stocat din nou eroarea. Daca da, ce contacte ar trebui sa verific? Nu ca as sti eu (decat daca e foarte foarte simplu si la vedere :) ) dar sa stiu sa ii spun mecanicului la ce sa se uite mai intai.
Mersi.
Offline murillo
  • Auto: O2 2.0 TDI
« Răspuns #151 : Mai 07, 2012, 04:04:14 p.m. »
Salutare,
Daca a schimbat cureaua de distributie si nu era bine pusa si-ar fi dat seama imediat.O distributie sarita de la punct face ''scandal''.Posibil sa fie o eroare memorata si care nu o sa mai apara ,odata stearsa,sau s-a dus senzorul de la axa...
Senzorul este undeva in jur de 2 mil.Vezi ca e diferit fata de unul de la o masina cu CV manuala.
Bafta!
Poate fi pusa gresit cu un dinte ca sa dea eroare "implausible signal" la G40...
Nu te grabi sa cumperi senzorul inca. Vezi daca reapare, verifica problema de mai sus, verifica partea de contacte.
« Răspuns #150 : Mai 07, 2012, 03:36:28 p.m. »
Mersi inca o data, acum sper sa nu mai apara, revin aici si cu "deznodamantul".
Daca gasesc iarasi stocata eroarea aia am sa fac o programare pentru schimbul senzorului.
Ce se intampla daca merg cu el asa?
Daca s-a defectat la schimbul distributiei e posibil sa-l fi lovit cei care au schimbat distributia si sa trebuiasca doar reasezat? Asta ar fi culmea, dar cine stie...
« Răspuns #149 : Mai 07, 2012, 03:21:54 p.m. »
Trebuie desfacut totul ca la schimbul de distributie?  :042:
Pai se afla la axul cu came acest senzor... Daca nu mai reapare poti rasufla usurat.
Nu stiu sa-ti spun exact ce semnifica acel "254"...
« Răspuns #148 : Mai 07, 2012, 01:16:37 p.m. »
Desigur ; Daca vrei si diseara. 0744-389.218.
« Răspuns #147 : Mai 07, 2012, 01:09:11 p.m. »
M-ati pus pe jar.  :-SS
Numarul de km la care a aparut eroarea respectiva (109211) sunt cel mai probabil (verific exact diseara) imediat dupa schimbarea distributiei. E posibil sa fi facut baietii o prostie la schimbul distributiei?
Revin si eu cu intrebarea lui iwolffy:
Fault Frequency: 254 ?  Ce semnifica? A aparut de 254 de ori ?
Daca e asa inseamna ca 99% e o problema. Totusi nu ar trebui sa indice numarul kilometrilor cand a aparut ultima data eroarea?
Dupa ce a fost stearsa eroarea nu a mai aparut la scanarea de imediat dupa, dar nici nu am pornit motorul inainte de re-scanare.
Cred ca trebuie sa ii fac inca o diagnoza. Iulian, ma mai ajuti o data zilele astea? :)
Senzorul nu e scump dar manopera...echivaleaza cu cea de la schimbul de distributie :(
« Răspuns #146 : Mai 07, 2012, 11:45:04 a.m. »
[Azi la 06:39:56 p.m.]
