Autor Subiect: Tempomat  (Citit de 250284 ori)
Offline ThunderBlue
  • Mesaje postate: 3246
  • Auto: skoda octavia 2
Re: Tempomat
« Răspuns #224 : Iunie 24, 2009, 06:09:04 p.m. »
Poate-i uairles  :D
Re: Tempomat
« Răspuns #223 : Iunie 24, 2009, 05:59:58 p.m. »
Deci in ambele cazuri e fara fir  :D ? Nu cred !
Offline Tom
  • Mesaje postate: 511
  • Auto: TOUR 101CP AXR 2007
Re: Tempomat
« Răspuns #222 : Iunie 24, 2009, 05:39:54 p.m. »
Tempomatul il gasesti ca:
1- accesoriu-atunci il iei fara firul suplimentar
2- piesa de schimb- atunci il iei fara firul suplimentar.
  Codurile difera, la fel si pretul- ca piesa de schimb e mai ieftina(la reprezwentanta) cu 30Ron).
Offline St3ff
  • Mesaje postate: 1732
  • Auto: O2 1.9 TDI BXE
Re: Tempomat
« Răspuns #221 : Iunie 23, 2009, 11:21:10 a.m. »
1K0 953 513 G daca nu ma insel
Offline B e b e
  • Locaţia: B-sti
  • Mesaje postate: 1268
  • Auto: O2 My2008 1.6FSI
Re: Tempomat
« Răspuns #220 : Iunie 23, 2009, 10:55:00 a.m. »
Sunt un pic in ceata :(
Am cerut niste oferte pe la niste firme si unele mi-au cerut codul piesei (tempomatul). Am cautat (putin intr-adevar) si n-am gasit decat chestia asta din care io inteleg ca e vorba de computerul de coloana ..adica chestia in care intra tempomatul (corectati-ma daca gresesc).
Exista cumva mai multe tipuri de manete sau sunt astia amatori ?
Ma puteti ajuta totusi cu un cod ?
Steering Column Control Module
There are 2 types of steering column control modules, each of them has 3 variants. The type is depending on the installed slip ring, either use the part number of the currently installed module or the part number of the slip ring to determine the correct module for the vehicle in question.
Type I (Compatible to Slip Ring: 1K0-959-653, 1K0-959-653-A)
Lowline
Part Numbers: 1K0-953-549
Supported Features: None
Midline
Part Numbers: 1K0-953-549-A
Supported Features: Cruise Control, Trip Computer
Highline
Part Numbers: 1K0-953-549-B, 1K0-953-549-D, 1K0-953-549-AD, 1K0-953-549-AM
Supported Features: Cruise Control, Trip Computer, Multi-Function Steering Wheel
Type II (Compatible to Slip Ring: 1K0-959-653-C, 1K0-959-653-D)
Lowline
Part Numbers: 1K0-953-549-E, 1K0-953-549-AE
Midline
Part Numbers: 1K0-953-549-F, 1K0-953-549-AF, 1K0-953-549-AH, 1K0-953-549-AP, 1K0-953-549-BC, 1K0-953-549-BF, 1K0-953-549-BN, 1K0-953-549-CA
Highline
Part Numbers: 1K0-953-549-G, 1K0-953-549-AG, 1K0-953-549-AK, 1K0-953-549-AL, 1K0-953-549-AQ, 1K0-953-549-BD, 1K0-953-549-BK, 1K0-953-549-CC, 1K0-953-549-CD
Note: 1K0-953-549-BC may have a Bug which doesn't allow Cruise Control Retrofitting, in such a Case you need to replace the Module.
VagCom 908
Offline Owe
  • Locaţia: Drobeta
  • Mesaje postate: 901
  • Auto: 1,9 TDI, BXE
Re: Tempomat
« Răspuns #219 : Iunie 22, 2009, 04:14:11 p.m. »
Ii dai 100 si iti da rest 5. :082:
 :D
« Ultima Modificare: Iunie 22, 2009, 09:45:10 p.m. de Owe »
Offline B e b e
  • Locaţia: B-sti
Re: Tempomat
« Răspuns #218 : Iunie 22, 2009, 12:29:50 p.m. »
motaj la brady e 350-450ron daca ma iau dupa mailu primit de la ei .. ca sa nu mai zic de pretul piesei
Iulian pretu e in ron la bnr ? sau vrei la propriu 95E
VagCom 908
Offline CristianH
  • Locaţia: Sighisoara
  • Mesaje postate: 1028
  • Auto: Ex SOT 1.9tdi, ALH
Re: Tempomat
« Răspuns #217 : Iunie 19, 2009, 07:56:07 p.m. »
Pentru OII este mai ieftin in mod sigur.
« Ultima Modificare: Iunie 21, 2009, 06:42:52 a.m. de CristianH »
Offline B e b e
  • Locaţia: B-sti
Re: Tempomat
« Răspuns #216 : Iunie 19, 2009, 07:36:37 p.m. »
cam scump ;) ... raman pe piata neagra ca sunt zgarcit :D
VagCom 908
Offline leonard_c
  • Locaţia: Iasi,Romania
  • Mesaje postate: 185
  • Auto: 1,6 MPI BSE
Re: Tempomat
« Răspuns #215 : Iunie 19, 2009, 07:00:25 p.m. »
La Open Service Iasi 480 tempomatul plus 200 manopera!
Re: Tempomat
« Răspuns #214 : Iunie 19, 2009, 05:37:47 p.m. »
Nu se leaga de asa ceva . Nu cred ca-i intereseaza . La Sibiu NP .
Offline B e b e
  • Locaţia: B-sti
Re: Tempomat
« Răspuns #213 : Iunie 19, 2009, 05:30:39 p.m. »
Intrebare: daca am masina in garantie si imi pun tempomat, cei din service isi pot da seama (doar uitandu-se prin computer si nu prin fisa tehnica a masinii) ca nu a fost pus de ei sau vreun service autorizat ?
VagCom 908
Re: Tempomat
« Răspuns #212 : Iunie 19, 2009, 02:17:47 p.m. »
Manopera se stabileste si functie de beneficiarul lucrarii . Baietii de la receptie au scoli inalte de psihologie . Chiar si mie au incercat sa-mi explice cate au de demontat si de montat cand am fost cu colegul . Le-am spus ca mie care am desfacut pentru prima data pe acolo sa-mi montez la masina mea tempomat nu mi-a trebuit mai mult de 30 minute de lucru efectiv ( fara activare , numai treaba de necalificat )
Re: Tempomat
« Răspuns #211 : Iunie 19, 2009, 02:10:20 p.m. »
nu inteleg ce i-au putut face de 230 ron acelui tempomat!eventual i-au dat de deochi :047:
Re: Tempomat
« Răspuns #210 : Iunie 19, 2009, 02:08:12 p.m. »
Sunt foarte curios daca la Intercar Sibiu manopera este de 100 lei pentru montare tempomat la Skoda Octavia TOUR.
La Intercar , am fost eu sa montez pe O II Combi a unei cunostinte , tempomat de RS second hand cumparat de pe forum , costul manoperei si a activarii 65 lei - factura . Nu s-a lucrat mai mult de 35 - 45 minute . Nu s-a reusit activarea din prima , dar pana la urma totul OK .
26 27 28 [29] 30 31
