Autor Subiect: Ce ulei de motor folosim?  (Citit de 591593 ori)
Re: Ce ulei de motor folosim?
« Răspuns #1172 : Februarie 17, 2013, 08:37:04 p.m. »
Despre TBN: http://en.wikipedia.org/wiki/Total_Base_Number
Adi, dupa ce-am citit aici despre TBN, cred ca valorile lui pt uleiuri sunt numa un reper in alegerea lor si nu fac diferenta si de calitate intre ele neaparat:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=688596
"It's not higher TBN is better. A higher TBN for UOA means with other factor's such as low wear, silcone, and higher antiwear addives such as zinc, moly, to name the popular ones. This will help with deciding your OCI. It's the retention of TBN that matters most."
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2276038
"I think the best way to look at this number is by how effective whatever TBN additives are used in the formula, relative to how well it is keeping TAN in check. A high starting TBN, or even reserve alkalinity at the end of an OCI means nothing if the chemistry of the oil allowed acids to build up unsafely. So, in short, don't pick the oil you want to use based on a higher starting or ending TBN alone. How effective the TBN is in use is more important."
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2491103
"Some oils need high TBN to combat their own chemistry (think ester-heavy formulas like Redline, 300V, RLI, etc)."
sau
"The TBN of new oil indicates a few things, but not a deciding factor. The quality (cost) of the components that create the TBN is more important. The remaining TBN of the oil after it has a lot of miles on it is more important than the starting TBN. Bottom line---buy an oil with an excellent track record, not one with any certain item on its spec sheet."
De citit si aici: http://www.edmunds.com/car-care/whats-your-engine-oil-telling-you.html
"Even if the TBN is 1, it doesn't mean the oil isn't doing its job," said Ryan Stark, president of Blackstone Laboratories. "But it does reveal the rate at which the additives are being used up."
« Răspuns #1171 : Februarie 17, 2013, 08:17:24 p.m. »
Eu il comand de 2 ani numa la importatorul din Sibiu.
Nu mi s-a intamplat sa intalnesc bidoane cu nepotrivirile mentionate de tine... ce-i drept folosesc numa 2 tipuri de ulei, ambele cu origine sigura 100%. Nu stiu nimic despre cei de la ICEM...poate aflati voi mai multe.
Offline Cromatic
  • Mesaje postate: 69
« Răspuns #1170 : Februarie 17, 2013, 08:03:37 p.m. »
Are cod EAN de Germania dar nu e relevanta chestia asta.
Codul de tara din EAN reprezinta locul unde firma producatoare este inregistrata - am vazut Mobil1 cod UK pe care scria "Made in Turkey" si  Mobil3000x1 cod UK pe care scria "Made in France" .
gti_mars, nu stiu ce sa zic, reprezentantul de acolo mi-a spus ca nu e o regula, unele vin Made in Germany iar altele Made in EU. De curiozitate, daca ajungi pe acolo vezi unde e fabricat cel care il folosesti tu. Apropo, tu de unde-l iei?
« Ultima Modificare: Februarie 17, 2013, 08:10:30 p.m. de Cromatic »
Trecut-FABIA Elegance 1,4 16v 101 HP    Prezent-LOGAN Kiss FM 1,4 8v 75HP
Offline gti_mars
  • Mesaje postate: 527
  • Auto: O II 4x4
« Răspuns #1169 : Februarie 17, 2013, 07:54:06 p.m. »
Aoleo, sper ca baietii de la Fuchs Lubricants nu fac uleiul aici. Din ce am vazut sunt in fostele hale ale ICEM-ului !
« Răspuns #1168 : Februarie 17, 2013, 07:31:53 p.m. »
Vezi aici cum se "decodifica" codul de bare de pe etichetele de uleiuri auto:
http://makebarcode.com/specs/ean_cc.html
Offline Cromatic
« Răspuns #1167 : Februarie 17, 2013, 07:12:34 p.m. »
Anul trecut, inainte sa fac schimbul de ulei, la recomandarea cuiva am pus si eu ulei Fuchs(pana atunci nu auzisem inca de marca asta), respectivul m-a asigurat ca este "Made in Germany" insa dupa ce am dat comanda si l-am primit...surprise - era "Made in EU" .
Am folosit "Titan Supersyn Longlife 5W40" si l-am achizitionat de pe site-ul fuchslubricants.ro
« Ultima Modificare: Februarie 17, 2013, 07:14:39 p.m. de Cromatic »
« Răspuns #1166 : Februarie 17, 2013, 07:05:14 p.m. »
Primul si cel mai vechi importator se afla in Sibiu.
Offline gti_mars
  • Auto: O II 4x4
« Răspuns #1165 : Februarie 17, 2013, 06:54:17 p.m. »
Cromatic a spus ca e facut in EU.
Eu am aratat ce scrie pe bidonul meu practic, nu din vorbe.
Culmea norocului Fuchs Lubricants este la 2 strazi de mine si nu stiam. Ca sa nu mai fac comanda tocmai in Germania !
« Răspuns #1164 : Februarie 17, 2013, 06:48:01 p.m. »
Nu cred ca cineva isi bate capul sa falsifice un ulei de nisa, chiar si unul f. bun.
Offline gti_mars
  • Auto: O II 4x4
« Răspuns #1163 : Februarie 17, 2013, 06:46:11 p.m. »
Deci ce am bagat eu nu e fake.
« Răspuns #1162 : Februarie 17, 2013, 06:35:27 p.m. »
Fuchs se produce numai in Mannheim.
« Răspuns #1161 : Februarie 17, 2013, 06:33:05 p.m. »
Eu am atat Titan SuperSyn Plus cat si GT1 si difera inscrisurile pe eticheta, dar codurile de bare sunt identice ;) Chestie de marketing, posibil.
Offline gti_mars
  • Auto: O II 4x4
« Răspuns #1160 : Februarie 17, 2013, 06:30:48 p.m. »
Salut !
Nu stiu de unde ai bagat Fuchs-ul "Made in EU", dar eu am bagat asa ceva !
« Ultima Modificare: Februarie 17, 2013, 06:35:42 p.m. de gti_mars »
« Răspuns #1159 : Februarie 17, 2013, 06:27:50 p.m. »
Verifica codul de bare, e identic cu cel de pe etichetele SuperSyn Plus (facute pana in toamna 2012), pe care scrie Made in Germany. ;)
Offline Cromatic
« Răspuns #1158 : Februarie 17, 2013, 05:39:50 p.m. »
De unde ai comandat Fuchs ?
Importator si distribuitor al produselor FUCHS pentru Romania cu sediul in Bucuresti - http://fuchslubricants.ro
Au cei de la Titan Trade si Fuchs cu norma 507.00? M-am uitat pe site dar nu am gasit.
TITAN GT1 PRO C-3 SAE 5W-30 XTL-technology
[/font]Da, si stii de ce ? Pt ca au origine controlata, adica sigura.
Fuchs de ex se produce numa in Germania.
Daca se produce numai in Germania, de ce scrie pe bidon "Made in EU" ?
« Ultima Modificare: Februarie 17, 2013, 05:41:27 p.m. de Cromatic »
