Autor Subiect: La cat se schimba cureaua de distributie?!?  (Citit de 366948 ori)
Offline Iorgovan
  • Locaţia: Cluj Napoca
  • Mesaje postate: 378
  • Auto: Octavia 2 1,6i Combi
Re: La cat se schimba cureaua de distributie?!?
« Răspuns #338 : Ianuarie 17, 2013, 09:13:57 p.m. »
Postez si eu raspunsul celor de la fabrica in legatura cu schimbarea curelei de distributie la 1,6 mpi (BSE).
Masine mea e din 2007 si in februarie va avea 6 ani, 77.ooo km; nu s-a umblat inca la distributie.
" On the 14th of January 2013, we have received your email, where you have asked for the recommendation regarding the change of
the timing belt of your ŠKODA Octavia (TMBHA61ZXXXXXXXXX).
As you have correctly mentioned in your email, the first visual control of the timing belt condition is set to 90000 km and
there is no time related limitation. If you are worried about the status of the belt then please ask your authorized service to
do the check by the next scheduled service check, but it should be sufficient to leave it to the limit set by the manufacturer.
Any premature change of the belt certainly won´t harm the engine but the control limit was set after many tests to keep the low
maintenance costs for the user.
In case of any questions don´t hesitate to contact us again.
Best regards,
Ing. Jaromír Tesař, PST - Péče o zákazníka, Customer Care, Kundenbetreuung
ŠKODA AUTO a.s., V. Klementa 869, 293 60 Mladá Boleslav, Czech Republic
info@skoda-info.cz , www.skoda-auto.com "
Eu intentionez sa o schimb anul acesta, insa am zis inainte sa arunc o intrebare direct la sursa. Acum dupa raspunsul producatorului ar insemna ca pina la 90 mii de km nu ar trebui sa apara probleme. :-~
« Ultima Modificare: Ianuarie 17, 2013, 09:35:50 p.m. de Iorgovan »
« Răspuns #337 : Ianuarie 09, 2013, 12:44:53 p.m. »
Ca la carte ar fi sa schimbi role + curea distrib + curea accesorii + pompa apa + lichid racire.
Eu iti spun insa ca dupa mine ar fi suficient sa schimbi ambele curele si lichidul racire numa.
Offline bogdancib
  • Auto: Skoda Octavia2 1.6
« Răspuns #336 : Ianuarie 09, 2013, 11:17:49 a.m. »
Buna ziua, imi cer scuze daca o sa  mai gresesc dar este primul meu  topic pe forum.Am cumparat in toamna lui 2012 o Skoda Octavia 2 de 1.6 MPI  102 CP din 2008 cu 12.000 km. masina nu prea a circulat mai mult a stat  prin garaj si a-si vrea sa ma ajutati cu un sfat multi mi-au spus sa schimb distributia toata ca masina nu a circulat,alti ca nu sa schimb doar curelele ca imbatrinesc si se crapa.Acum nu stiu pe care sa o iau de buna va rog daca se poate sa ma ajutati cu un sfat o parere.Va multumesc mult.
« Răspuns #335 : Ianuarie 08, 2013, 08:17:44 p.m. »
Este OK, dar cel mai bun este sa le iei pe repere separate: role INA si curea Conti.
Pompa apa Hepu e f OK.
Maxim 5 ani sau 90.000km (la extended life service merge 120.000km), oricare intervine prima ;)
« Răspuns #334 : Ianuarie 08, 2013, 03:54:24 p.m. »
acum nu stiu in ce stadiu este kit-ul de accesorii (curea de accesorii/transmisie, rola fixa, si rola intinzatoare). La Renault ele se schimba la 4 ani si/sau 60000km...dar nu stiu la Skoda Ocavia care este intervalul precis, trebuie sa te uiti in cartea tehnica.
Offline Alecsoi
  • Mesaje postate: 4
  • Auto: Skoda Octavia Tour
« Răspuns #333 : Ianuarie 08, 2013, 03:35:12 p.m. »
 :056: ... este ok kit distributie gates + pompa de apa hepu ? ce trebuie sa mai cumpar in afara de kit si pompa apa !?
nu prea ma pricep si de aceea intreb ...  :042: sper sa nu sara lumea pe mine ca bag 2 topicuri. multumesc anticipat !!
« Răspuns #332 : Septembrie 21, 2012, 01:23:39 p.m. »
Reglajul avansului trebuie facut, dupa verificarea valorii actuale pe tester.
Consumul "se aseaza" dupa el.
Offline popam
  • Locaţia: Bistrita (Ro)
  • Mesaje postate: 484
  • Auto: SOT 1,9 TDI 74KW '08
« Răspuns #331 : Septembrie 21, 2012, 12:11:55 p.m. »
deci sa inteleg ca este ok sau pe acolo?
nu cred ca au mai pus-o pe tester, sau nu se poate altfel :-? :-? ??
din tester se poate regla mai jos putin sau tot mecanic?
am si facut 200km dupa schimb, parca merge altcumva!
am mai completat cu antigel, ca nu au apucat sa faca ture cu masina....
SOT  AXR 1,9TDI PD 2008  74KW
Incerc sa invat din mers...
« Răspuns #330 : Septembrie 20, 2012, 07:04:09 p.m. »
Reglajul avansului se face pt conformitate, insa se stie ca AXR-ul are consum relanti mai mare ca alte coduri 1.9TDI...
Offline bmarianr
  • Mesaje postate: 21
  • fast forward
  • Auto: O2 2TDI 4x4 BMM
« Răspuns #329 : Septembrie 20, 2012, 04:36:02 p.m. »
ma apropii si eu cu masina din semnatura de 90.000 si imi pun problema schimbarii distributiei in curand
citesc cu suspiciune despre faptul ca aveti consum la relanti de 0.8-0.9 ... in momentul de fata consumul la relanti afisat este de 0.4 fara consumatori si nu depaseste 0.6 cu ac, faruri ...
se inregistreaza cresteri ale consumului dupa (primul) schimb de distributie (cu sau fara a regla avansul) ?
2008 O2 Combi 4x4 2TDI BMM PDG
« Răspuns #328 : Septembrie 20, 2012, 04:32:35 p.m. »
Nu e cam mult 0.8 fara A/C ?
Eu am 0.7 pe 1.8 TSI; Am vazut ca altii pe forum aveau 0.4-0.5l/h la 1.9 TDI.
Poate mai trebuie umblat la avans...
Offline popam
« Răspuns #327 : Septembrie 20, 2012, 04:30:20 p.m. »
...ma tot uit la cureaua veche si zici ca e ca nou...
am schimbat, am platit, am vazut ca, consumul ramane la0.8 la relantiu, cum era innainte, cu tendinte la 0.9, nu aveam cu cine sa mai povestesc , cand am ajuns baietii erau plecati...tre sa cfompletez numa cu antigel , si amu o tai l adrum, deci ar trebui sa verifica de cateva ori sa nu scada de tot.
1040 per total a fost!
cu amanunte, mai tarziu ;)
Offline popam
« Răspuns #326 : Septembrie 20, 2012, 12:52:37 p.m. »
in concluzie...masina este de la ora 10 pe stand ...
nu mai este cale de intoarcere!
fiecare bordel cu obiceiul lui.
din cauza faptului ca nu scrie vw pe curea, garantia este de 50000, sau ceva de genu sau 18 luni...
Offline Tom
  • Mesaje postate: 511
  • Auto: TOUR 101CP AXR 2007
« Răspuns #325 : Septembrie 20, 2012, 12:20:07 p.m. »
Am intrebat la uzinele SKODA despre relatia TIMP-KILOMETRI in ceea ce priveste schimbarea distributiei.
Iata ce am intrbat eu:
  Hello!   I have a question about 1.9 TDI PD engine AXR, made ​​in 2007 (vin ----------------).  I understand that timing belt is to visually check at 90000km and change at 120000km. Many Skoda owners in Romania say that if you haven't done  those number of km, but it timing belt is five years old, it must be changed. It is indeed important the age in changing timing belt or just the number of kilometers made​​ ?  I refer here to aging rubber. I read that OEM parts have a lifetime longer than the aftermarket, but I don't know how much. In conclusion, count the kilometers made or the years old in  timing belt change? Thank you very much.
 Many thanks. Best regards,                          Radu POPA.
Iata si raspunsul primit:
Dear Mr. Popa,
on 17th of September we received your email in which you ask us for the timing belt change information. We confirm to you that
the belt is visually checked at 90000 km and it needs to be replaced at 120000 km. To replace your timing belt before this
mileage is possible at your discretion. The age of the belt is not the major factor but it influence its lifetime anyway. We
recommand you to visit your nearest workshop to consider if the replacement is needed.
Regarding to aftermarket parts we insist on original Skoda part usage. We wish you much driving pleasure with your Skoda.
Kind regards,
Richard Cejnar | PST - Péče o zákazníka, Customer Care, Kundenbetreuung
ŠKODA AUTO a.s. | V. Klementa 869 | 293 60 Mladá Boleslav | Czech Republic
info@skoda-info.cz | www.skoda-auto.cz | www.skoda-auto.com
Škoda - Simply clever.
Please consider the environment before printing this email.
Prosím, zvažte dopad na životní prostředí před tiskem tohoto mailu.
Offline popam
« Răspuns #324 : Septembrie 19, 2012, 09:49:27 p.m. »
bun, si cum imi dau seama ca avansul este sau nu este foarte reglat, sa stiu cum sa punctez daca este nevoie ?!
[Azi la 07:34:51 a.m.]
26 27 28 29 [30] 31
