Autor Subiect: coduri erori vag  (Citit de 424450 ori)
Offline xxleeus
  • Mesaje postate: 306
    • Cameraman nunti botezuri
  • Auto: 1.8TSI-DSG
Re: coduri erori vag
« Răspuns #238 : August 06, 2010, 10:52:32 a.m. »
Probleme cu butucul cheii de pornire. De verificat toate contactele/circuitele ce tin de butuc. Parerea mea  O:)
Filmari evenimente.
Offline Ioan
  • Locaţia: Hunedoara
  • Mesaje postate: 666
  • Auto: 1.9 TDI (BXE)
« Răspuns #237 : August 05, 2010, 05:50:11 p.m. »
Address 16: Steering wheel
Control Module Part Number: 1K0 953 549 BN
  Component and/or Version: J0527           051 0100
           Software Coding: 0000012
            Work Shop Code: WSC 73430
4 Faults Found
00576 - Terminal 15
        012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Idei ?
Offline serbanra
  • Mesaje postate: 20
  • Auto: Octi 2 140 CP DSG
« Răspuns #236 : Iulie 22, 2010, 07:10:40 p.m. »
Doar senzorul. Nu cred sa coste mult, pana in 200 ron.
Offline ionutblv
  • Locaţia: iasi
  • Mesaje postate: 87
  • BLV
  • Auto: Seat Leon 1m
« Răspuns #235 : Iulie 22, 2010, 05:36:35 p.m. »
Mersi Serban, ai idee cat ajunge?Schimb sonda sau senzorul? :042:
California Scents Odorizante
Offline serbanra
« Răspuns #234 : Iulie 22, 2010, 03:55:59 p.m. »
@ionutblv: trebuie sa schimbi senzorul de la sonda lambda. Vezi attachement.
Offline ionutblv
  • Locaţia: iasi
  • BLV
« Răspuns #233 : Iulie 22, 2010, 02:41:16 p.m. »
salutari!
ma ajuta careva:
VAG-COM Version: Release 704.1
Data version: 20071016
Monday,21,June,2010,20:44:31:59303
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ2R006055 Mileage: 152810km/94951miles
Address 01: Engine Labels: None
Part No: 036 906 032 M
Component: ME7.5.10 3871
Coding: 00031
Shop #: WSC 49794
VSSZZZ1MZ2R006055 SEZ7Z0A1242628
2 Faults Found:
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction
P1196 - 35-10 - - - Intermittent
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.LBL
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 00001
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Part No: 6Q0 909 605 A
Component: 1L AIRBAG VW5 0A 0006
Coding: 12620
Shop #: WSC 06441
Address 17: Instruments Labels: None
Part No: 1M0 920 802
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 04107
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Part No: 1C0 959 799 E
Component: 2U Komfortgerát HLO 0003
Coding: 00067
Shop #: WSC 06441
Part No: 1C1959801A
Component: 2U Tőrsteuer.FS KLO 0002
Part No: 1C1959802A
Component: 2U Tőrsteuer.BF KLO 0002
End --------------------------------------------------------------------------------------------------
E CEVA GRAV?
Offline serbanra
« Răspuns #232 : Iulie 22, 2010, 07:22:16 a.m. »
Vezi ca si la mine s-a aprins becul galben - emission workshop. Eroarea era tot de la EGR!
Da jos EGR-ul si verifica "cu gura" capsula vacuumatica. Daca nu mai trage tija inseamna ca membrana e sparta si trebuie sa schimbi corpul vacuumatic (350 ron).
Dupa aia trebuie sa stergi eroarea.
Bafta!
Offline Radek
  • Locaţia: Satu Mare, Romania
  • Auto: O2,1.9 TDI BXE 2008
« Răspuns #231 : Iulie 19, 2010, 06:59:27 p.m. »
Salutare,
Am si eu o problema cu Skoda mea, ruland prin oras am intampinat mesajul "Emissions Worshop!", citind manualul m-am indreptat spre service pentru o diagnoza, zis si facut, mi-a iesit egr-ul, ce de acolo ziceau ca trebuie schimbat, dar din cele citite pe net m-am pus sa-l curat, totul functioneaza doar ca desi azi am sters eroare a aparut din nou dupa aproximativ 10 km.
Va atasez eroarea:
Orice sugestie este bine venita.
« Răspuns #230 : Iunie 29, 2010, 06:25:34 a.m. »
Pune logul cu eroarea completa.
Offline mateib
  • Auto: skoda oct.II tdi 1.9
« Răspuns #229 : Iunie 28, 2010, 08:16:49 p.m. »
ce inseamna eroarea de motor p161 pt o octavia II 1.9 tdi? merci anticipat
Offline LucianPH
  • Auto: Octavia2 1.9TDI
« Răspuns #228 : Iunie 28, 2010, 12:00:07 p.m. »
Salut.
Ma poate ajuta cineva cu aceste coduri:
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: TMBCS41Z852052953 Mileage: 171390km/106496miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 DJ HW: 028 101 188 3
Component: R4 1,9L EDC 0000SG 6250
Revision: 12345678 Serial number: SKZ7Z0E2885525
Coding: 0000071
Shop #: WSC 73430 790 00000
1 Fault Found:
18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83): Signal too High
P2185 - 000 - -
Freeze Frame:
RPM: 798 /min
Torque: 42.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.83 V
Bin. Bits: 11000100
Temperature: 81.0°C
Temperature: 74.7°C
Readiness: 0 0 0 0 1
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104C280672
Coding: 3D3F0B40071302
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 81
Mileage: 171272 km
Time Indication: 0
Date: 2000.00.00
Time: 11:29:47
Simptome: motorul porneste ca naiba cand este cald (tremura din toate incheieturile). Cand este rece porneste perfect.
Aceste erori imi repar chiar si dupa ce le-am sters.
Erorea de la Auto HVAC era de la compresorul de AC. Am completat fronul si acum este OK. AC functioneaza.
Multumesc frumos de ajutor
Offline mirceone
  • Locaţia: brasov
  • Auto: skoda superb 1.9 tdi
« Răspuns #227 : Iunie 27, 2010, 08:16:30 p.m. »
buna!!!! detin un atoturism skoda superb din 2004 si va rog sa ma ajutati cu niste raspunsuri daca stiti  1) nu mai pot sa deschid usa dreapta spate  pe calc zice" ansambluinchidere F 223dreapta spate 27-10 semnal implauzibil-intermitent. va multumesc anticipat pentru ajutor
« Răspuns #226 : Iunie 16, 2010, 11:43:33 p.m. »
18000/P1592/005522 - Altitude Sensor / Boost Pressure Sensor:   Implausible Correlation
  Possible Symptoms
      * Malfunction Indicator Light (MIL) active
      * Limp Mode active
  Possible Causes
      * Wiring from/to Boost Pressure Sensor (G31) faulty
      * Ground Spots corroded
      * Boost Pressure Sensor (G31) faulty
  Possible Solutions
      * Check Wiring from/to Boost Pressure Sensor (G31)
      * Check Ground Spots for Corrosion
      * Check Boost Pressure Sensor (G31)
  Special Notes
      * When found in 2.0l TDI-PPD (BMN), check TSB/TPL's first.
            o Possible Causes: Software Issue, High Resistance in Engine   Wiring Harness, Ground Spots corroded
            o Possible Solutions: Check/Update Engine Control Module   Software, Check Wiring from/to Boost Pressure Sensor (G31), Check Ground   Spots for Corrosion
Offline mistik25
  • Locaţia: roman
  • Auto: octavia,101cp;1,9 AX
« Răspuns #225 : Iunie 16, 2010, 09:25:37 a.m. »
 :-<    Buna ziua,daca poate sa ma ajute cineva cu o problema ca nu stiu ce sa ii mai fac la masina,
am facut diagnoza si in memoria ecu este inregistrat urmatorul defect:
18000 - Altitude Sensor / Boost Pressure Sensor: Implausible Correlation
            P1592 - 000 -  -  - Intermittent
Masina nu trage de nicio culoare,nu face deloc presiune pe admisie.
Am verificat cablajul intre senzorul de presiune si ecu,am schimbat electrovana presiune turbo, am masurat depresiunea pe furtunul ce vine in electrovana este de -0,8;am masurat depresiunea pe furtunul ce duce de la electrovana la turbo fiind 0,0.Am verificat  daca am tensiune pt electrovana  este de 12v.
Nu stiu ce sa-i mai fac.
     Va multumesc
Offline VictorB
  • Locaţia: Sibiu, Romania
  • Mesaje postate: 98
  • Auto: AUB
« Răspuns #224 : Mai 07, 2010, 11:35:57 a.m. »
Deci senzorul de oxigen e sonda lambda? Imi poate explica cineva unde gasesc conexiunile astea? EGRul si sigurantele stiu dar senzorul acela de oxigen habar n-am unde sa-l caut.
Skoda Fabia 1.4 16v 101cp
