Autor Subiect: Tempomat  (Citit de 250142 ori)
Offline OutOfCtrl
  • Locaţia: TM
  • Mesaje postate: 70
Re: Tempomat
« Răspuns #134 : Martie 26, 2009, 12:15:15 a.m. »
Prin Timisoara aveti idee unde s-ar face asa ceva?
« Ultima Modificare: Martie 26, 2009, 12:35:58 a.m. de OutOfCtrl »
Octavia 2 '06, 1.9 TDI 105 CP BJB, jante 17", sasiu sport, ESP, muzica, folie, toba finala sport
Offline xxleeus
  • Mesaje postate: 306
    • Cameraman nunti botezuri
  • Auto: 1.8TSI-DSG
Re: Tempomat
« Răspuns #133 : Martie 16, 2009, 07:48:17 a.m. »
Presupunand ca operatiunea a fost efectuata de un meserias, acesta ar fi trebuit ca inainte sa dea verdictul ca maneta este defecta, sa se asigure ca functia respectiva este suportata de calculator...
Steering Column Control Module
There are 2 types of steering column control modules, each of them has 3 variants. The type is depending on the installed slip ring, either use the part number of the currently installed module or the part number of the slip ring to determine the correct module for the vehicle in question.
Type I (Compatible to Slip Ring: 1K0-959-653, 1K0-959-653-A)
Lowline
Part Numbers: 1K0-953-549
Supported Features: None
Midline
Part Numbers: 1K0-953-549-A
Supported Features: Cruise Control, Trip Computer
Highline
Part Numbers: 1K0-953-549-B, 1K0-953-549-D, 1K0-953-549-AD, 1K0-953-549-AM
Supported Features: Cruise Control, Trip Computer, Multi-Function Steering Wheel
Type II (Compatible to Slip Ring: 1K0-959-653-C, 1K0-959-653-D)
Lowline
Part Numbers: 1K0-953-549-E, 1K0-953-549-AE
Midline
Part Numbers: 1K0-953-549-F, 1K0-953-549-AF, 1K0-953-549-AH, 1K0-953-549-AP, 1K0-953-549-BC, 1K0-953-549-BF, 1K0-953-549-BN, 1K0-953-549-CA
Highline
Part Numbers: 1K0-953-549-G, 1K0-953-549-AG, 1K0-953-549-AK, 1K0-953-549-AL, 1K0-953-549-AQ, 1K0-953-549-BD, 1K0-953-549-BK, 1K0-953-549-CC, 1K0-953-549-CD
Note: 1K0-953-549-BC may have a Bug which doesn't allow Cruise Control Retrofitting, in such a Case you need to replace the Module.
Filmari evenimente.
Re: Tempomat
« Răspuns #132 : Martie 16, 2009, 07:17:38 a.m. »
"ciobanul" este electrician la AutoGrup si a montat zeci de tempomate. Prin urmare cred totusi ca piesa este de vina, fiind SH, din cate am inteles.
Offline Cristi 71
  • Cont sters
Re: Tempomat
« Răspuns #131 : Martie 16, 2009, 06:39:54 a.m. »
Nici nu ai ce fir sa tragi deoarece manetele (si cea fara si cea cu tempomat) se conecteaza la o singura mufa si aia are toate firele deja trase...
Eu l-am intrebat pe colegul ThunderBlue daca cel care i-a montat maneta i-a facut si activarea functiei, deoarece mi se pare greu de crezut ca o maneta noua care are niste simple contacte "mecanice" sa fie defecta. Si sa ai norocul ca sa fie defect chiar contactul ON-OFF... Verificarea contactelor e o chestie banala.
In cazul lui, daca cel care a montat maneta a efectuat corect si procedura de activare, ne aflam in situatia descrisa mai sus de Master4x4 (calculatorul nu este compatibil cu functia respectiva). Presupunand ca operatiunea a fost efectuata de un meserias, acesta ar fi trebuit ca inainte sa dea verdictul ca maneta este defecta, sa se asigure ca functia respectiva este suportata de calculator...
Concluzia mea: 1% sanse ca maneta sa fie defecta si 99% sanse ca "meseriasul" sa fie cioban...
Re: Tempomat
« Răspuns #130 : Martie 16, 2009, 05:26:59 a.m. »
Logic ce ai scris , dar nu este asa de regula . Persoane care cunosc , Vali1970 , un coleg , eu , nu am avut tempomat ca optiune la cumpararea masinii . Toti ne-am montat AM tempomat . Vali 1970 si eu tempomat avand cod de piesa de schimb , iar colegul tempomat SH provenind de pe un RS . Niciunul din noi nu am schimbat calculatorul de coloana si nu a trebuit tras fir de la maneta la calculatorul de coloana . Eu am inteles dintr-o discutie cu cei care lucreaza la reprezentanta ca la modelele de Octavia 2 , incepand cu MY 2007 , firul de la maneta la calculatorul de coloana exista , deci cred ca se monteaza din fabrica calculatoare de coloana care suporta si functia de CC.
Offline Giovanni_23
  • Mesaje postate: 382
  • Auto: Octavia 2 1.9 TDI
Re: Tempomat
« Răspuns #129 : Martie 16, 2009, 02:25:32 a.m. »
  Foarte tare!!!deci octavia 2 are 3 calculatoare ale coloanei de directie.........astea se monteaza in fabtica in functie de optionalele cerute,banuiesc!!!daca masina nu este prevazuta cu Tempomat din fabrica,logic ar fi sa nu ai montat nici calculatorul coloanei de directie care ar permite montarea tempomatului after market!!!LOGIC asa ar fi!!!Nu???  :-?
Re: Tempomat
« Răspuns #128 : Martie 16, 2009, 12:40:55 a.m. »
La Octi 2 exista 3 tipuri de calculatoare ale coloanei de directie...trebuie intai verificat daca cel posedat accepta cruise control sau nu, abia apoi achizitionat CC-ul.
Offline ThunderBlue
  • Mesaje postate: 3246
  • Auto: skoda octavia 2
Re: Tempomat
« Răspuns #127 : Martie 15, 2009, 06:52:17 p.m. »
Maine ma intalnesc din nou cu el. A zis ca intai o sa testeze maneta, daca nu merge nici asa...e clar
Re: Tempomat
« Răspuns #126 : Martie 15, 2009, 06:29:24 p.m. »
Pai, a dat bordul jos, a schimbat maneta, a pus bordul la loc etc. A facut activarea cu laptoapa dupa care am plecat in probe. Am facut niste ture si nimic. S-a mai verificat inca o data cu scula, s-au facut iar probe etc. Nimic. S-a dat din nou bordul jos, mi-a montat maneta mea la loc si cam asta a fost. Sper sa o rezolv saptamana viitoare.
Nici la mine nu a mers in parcare activat . A trebuit sa ma duc la reprezentanta sa puna VAS-ul . Au reusit din a doua incercare .
Dupa cateva luni am cumparat de pe forum o maneta tempomat pentru un prieten , care a fost pe un RS si din nou nu s-a putut face activarea de data aceasta cu VAS-ul , pana nu l-am sunat pe BLITZ ( Cristi ) , care a fost profesorul . Vezi ca poate maneta e buna , dar meseriasii gresesc pe undeva .
Offline Cristi 71
  • Cont sters
Re: Tempomat
« Răspuns #125 : Martie 15, 2009, 05:58:47 p.m. »
Despre ce fir spre ECU si ce gauri e vorba? Nu a dat nici o gaura si nu a atarnat nici un fir. Doar a scos mufa de la maneta veche si a conectat-o la cea noua! Iar volanul trebuie sa fii dobitoc sa-l pui gresit deoarece pozitia e marcata din fabrica.
Re: Tempomat
« Răspuns #124 : Martie 15, 2009, 05:12:58 p.m. »
mari mesteri grabiti sunt destui
de regula asa si iese treaba: se remonteaza aiurea volanul si se schimba valorile date de senzor, firul spre ECU spanzura cine stie pe unde, iar gaura data in cutia cablarailor e mare cat china ca sa mai poata intra si o tura de praf etc
eu de astia vitezistii am oroare; de regula incearca sa compenseze prin viteza anduranta :D
« Ultima Modificare: Martie 15, 2009, 06:25:02 p.m. de FABIAn RuSu »
Offline ThunderBlue
Re: Tempomat
« Răspuns #123 : Martie 15, 2009, 05:12:17 p.m. »
Offline Cristi 71
  • Cont sters
Re: Tempomat
« Răspuns #122 : Martie 15, 2009, 04:22:39 p.m. »
Cine sa i-l activeze? Pai ala care i l-a montat!
20 de minute e mult... Mie mi l-a montat un flacau care e electrician la reprezentanta. A scos numaidecat bordul si volanul, dupa care a inlocuit manetele si a pus totul la loc. Am stat langa el, pe scaunul din dreapta. Iar activarea cu laptop-ul n-a durat nici cinci minute, dupa care a dat o tura cu mine sa se asigure ca-i OK.
Offline geolik
  • Mesaje postate: 763
    • Blog
  • Auto: Octavia Tour, 1.9PD
Re: Tempomat
« Răspuns #121 : Martie 15, 2009, 01:17:59 p.m. »
Cine, Chuck Norris?
20 minute e cam putin, parerea mea!
G.
Offline Cristi 71
  • Cont sters
Re: Tempomat
« Răspuns #120 : Martie 14, 2009, 08:27:14 p.m. »
A efectuat si activarea lui cu laptop-ul, ca nu-i suficient doar sa monteze maneta. Iar montajul n-are cum sa dureze mai mult de 10-15 minute. Mie mi l-a montat pe intuneric noaptea in parcare si a durat cu tot cu activarea functiei mai putin de 20 de minute...
[26] 27 28 29 30 31
